Need help with window switch.
Old Feb 21, 2007 | 04:37 PM
Maximahappy22's Avatar
I just recieved my MSD digi window switch with tach and im sorta confused about which wire should go to the soleniod. The instructions say that the grey wire is normally closed which i think means the item it is hooked up to is ON, then the yellow says normally open which i think means the item is normally off. so would i need to put the yellow into my nitrous solenoid or the gray?
these are the instructions. http://www.msdignition.com/pdf/8969_frm25515.pdf
Also would i need to splice the yellow/gray wire to go to the fuel soleniod too?
Alex
Old Feb 21, 2007 | 04:53 PM
This is pretty crude but i think this is how it is suposed to be, correct me if im wrong!
Old Feb 21, 2007 | 07:09 PM
t6378tp's Avatar
Turbo 3.5
they give you a diagram with the instructions, but yes the ground from the msd is your ground for the nitrous
Old Feb 21, 2007 | 07:27 PM
So my diagram is correct?
Old Feb 26, 2007 | 08:00 PM
On my 3rd gen i dont know which prong is the output for my RPMs on the ECU. does anyone know what prong it is?
Old Feb 27, 2007 | 08:23 AM
t6378tp's Avatar
Turbo 3.5
I do not know which pin on the ecu for a 3gen but you can try tapping the tach wire in the dash
Old Feb 27, 2007 | 06:10 PM
that is what i was thinking, i am going to try it on friday to see if i can get it to work because im installing the nitrous on sunday.
Anyone else know?
gavin68
Sep 18, 2021 12:36 PM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
