Nitrous questions
Old Oct 28, 2008 | 01:50 PM
viperboy's Avatar
Nitrous questions
I know there is a forum specifically for nitrous, but I didn't see many threads specific to the 3.5L. I was just wondering what people are running. This would be a mod for a little later down the road, I'm just still trying to read about it. What is the best kit to buy, a wet or dry? I would wanna run a kit on an all stock motor (with the exception of the GAB v2 mod, not that it makes a difference). It is my daily, and I would only use nitrous every now and then. It needs to be RELIABLE. From what I read, if you choose a good kit for a stock setup, you can run one safely and not affect reliability as long as you're not running the living **** out of it all the time. I have a 6MT, so would the stock clutch be fine? How easy is it to install and how long does it take? Thanks
Old Oct 28, 2008 | 04:32 PM
VQP0WER's Avatar
Post this in the Nitrous forum. You also didnt need to post two of the same thread in here.
Old Oct 28, 2008 | 05:05 PM
AceofSpds's Avatar
wat
same things for 3.0 would apply to your 3.5
a key part for you is getting an rpm window switch since you are 6spd
Old Oct 29, 2008 | 05:08 AM
viperboy's Avatar
Didn't mean to, I guess it double posted.
What do you mean about the rpm switch? Sorry, I'm unfamiliar with nitrous. I'll look around and post in the Nitrous forum too.
Old Nov 1, 2008 | 06:12 PM
irish44j's Avatar
retired moderator
Use it. Moving...
Old Nov 2, 2008 | 05:42 AM
viperboy's Avatar
Originally Posted by irish44j
Use it. Moving...
Already posted one there. You can delete this thread.
Old Nov 2, 2008 | 06:53 AM
KRRZ350's Avatar
Many of the questions are in the FAQ's up above, you should read them first, if you have any further questions I would love to help.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
