few questions
Old Jul 17, 2009 | 01:06 PM
nismoSEXIMA's Avatar
few questions
i have a 2001 SE 5-speed i just got a nitrous kit off my friends only gonna run a 50 shot for now street use and a 75 track and dyno... with either of those should i buy new spark plugs? I read about people using copper spark plugs. also what should i adjust my timing to??
Old Jul 17, 2009 | 01:42 PM
jr schultz's Avatar
Stock timing and 1 step colder copper plugs for 50 and 75 shot.
Old Jul 29, 2009 | 09:36 PM
ojeda112's Avatar
would ngk iridium be ok for nitrous?
Old Jul 30, 2009 | 10:37 AM
krazy6's Avatar
Don't use iridium plugs. Always go copper with nitrous.
Old Aug 3, 2009 | 03:18 PM
Jime's Avatar
I have used NGK Iridium plugs with nitrous for the last 3 years.
What is your experience with them?
Old Aug 4, 2009 | 12:49 AM
krazy6's Avatar
Just have heard from guys at the track that run huuuuuge shots to not run iridium plugs.
I never used an iridium plug in my camaro and it ran perfect on the spray and never burned a plug.
Don't have any experience with them myself though.
Old Aug 4, 2009 | 08:10 AM
dfownz's Avatar
As long as they're one step colder the only difference is iridiums last longer right?
Old Aug 4, 2009 | 08:27 AM
Jime's Avatar
Ya, a lot longer. Mine are 2 steps colder and I run them N/A as well because I am too lazy to swap them all the time and I ran my record N/A time with them. Have also ran a 200 shot with no problem.
Old Aug 4, 2009 | 12:05 PM
krazy6's Avatar
Not 100% sure, but the iridium plugs get hotter. The tips can burn off easier.
The fastest maxima is using iriduims, so they must work.
Old Aug 4, 2009 | 12:52 PM
grey99max's Avatar
LandShark has Cosworth
I've melted tips off of several iridium plugs in my 3.0 - that's why I quit using them.. looked like melting candles. Dunno why, either, although the ground straps would sometimes be damaged. After I went to cutting back the ground straps and used copper-core plugs, the plug problems were much less. Still can't run too lean, though.
Old Aug 12, 2009 | 07:28 AM
grey99max's Avatar
Originally Posted by Shift_Knob
iridiums are not that bad for small shots but DO NOT use platinum plugs as the platinum and the nitrous has a bad chemical reaction and can burn holes in pistons. i just got rid of my 94 Lincoln Mark VIII and i ran auto light copper plugs in it with a 100 dry on it and it took it fine.
So, what was it like running the Lincoln on that much nitrous???
Old Aug 12, 2009 | 08:14 AM
Juiced SE-R's Avatar
I've run iridiums the last two years, no problems at all. Just have to keep any eye on the like any other spark plug when using nitrous.. It's all personal prefrence though. Either way good luck..
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
