electronic WOT switch for DR mod?
Old Aug 24, 2009 | 02:23 PM
nzelinsky's Avatar
Hey I am trying to figure out how to set up a wot switch for the drop resistor mod. I have a 5.5gen which is dbw so I need electronic switch.
http://www.nitrousexpress.com/produc...ils.php?id=336
Will this work? I know the circuit has to be normally closed... does anybody know how these work is it normally closed or open? If it is normally open is there a way to modify to make it normally closed?
Old Aug 24, 2009 | 05:01 PM
t6378tp's Avatar
Turbo 3.5
with a 5 pin relay
Old Aug 26, 2009 | 01:53 PM
nzelinsky's Avatar
huh? care to elaborate, I have no idea what you are talking about
Old Aug 27, 2009 | 01:09 PM
krazy6's Avatar
Pretty sure he is talking about something like this:
http://www.dynotunenitrous.com/store...p?idproduct=47
Old Aug 27, 2009 | 01:24 PM
nzelinsky's Avatar
So you modify the tps sensor switch with that relay? sry Im not very good with electronics...
Old Aug 27, 2009 | 07:12 PM
t6378tp's Avatar
Turbo 3.5
wire it like this, tps sensor to the relay, relay to the drop resistor
when you go wot the tps will activate the tps sensor which will send 12v to the relay and activate it, then if your using a 5 pin relay use the normal closed circuit so when powered the relay will pull power and switch to open disconnect the drop resistor giving you a drop mod activate by a tps wot switch
Old Aug 27, 2009 | 09:10 PM
nzelinsky's Avatar
Okay thanks, Now I just have to find somebody who understands all this electric-ese to install it for me... Im not very handy with anything besides nuts and bolts
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
