05-06 stage 2 stillen supercharger for g35 auto
Old Jun 22, 2016 | 02:41 PM
R29241's Avatar
Will this supercharger fit an stock 02 vq35de 3.5l maxima? Your help. Would be greatly appreciated. Need answers ASAP cause offer is going g to go fast.
Old Jun 22, 2016 | 02:53 PM
No ...
RWD set-up vs FWD. (transverse engine). There have been a few custom twinscrew set-ups.
Old Jun 22, 2016 | 03:21 PM
R29241's Avatar
Thanks for the quick response I am really looking for a cheap supercharger that will fit. Cause it's a automatic and I. Not trying to kill it. I. I. A budget I want to feel that boost.
What supercharger you have on ur setup?
Old Jun 22, 2016 | 03:55 PM
Mattx's Avatar
You got the wrong car unless you can A. Do all the work yourself and B. Be able to custom make your own setup. There's next to no aftermarket support for these cars and what parts are available usually aren't cheap. If you're looking to go with a supercharger it's going to be a lot of custom work. No bolt on kit for a 5.5 gen.
Old Jun 22, 2016 | 04:49 PM
R29241's Avatar
I'm fine with that on a budget just wondering where 2 start. Exhaust or suspension? Or a cheap. Supercharger if I can find one
Old Jun 22, 2016 | 09:36 PM
Mattx's Avatar
I'd start with familiarizing yourself with the different options you have as far as boosting a maxima. If you mean what to buy/upgrade first? That's easy for an auto, that would be transgo hd2 shift kit. I wouldn't even attempt boosting an auto without one. Installing the kit will be good with or without boost. If you're looking for an upgrade that's one of the best for an auto.
As far as finding a cheap blower goes, I guess it depends on your definition of cheap. The blower isn't the problem to find it's making it work on the car. You won't be able to buy a kit that you can install. If you had a 00/01 then yea you might find something. Nothing was ever designed for our model. You would be designing a mount that works on our timing cover and other obstacles. I really think you need to read up on the car. A good place to start is in this section if you're planing on forced induction. In my opinion you'd be better off with a turbo setup. You can do it on a budget but it's still going to cost 3-5gs. That's the very low end. You won't be able to safely do it for under the 3G mark I'd say. That's being patient and waiting for the right deal. Also buying a lot of used parts.
These aren't civics where you can spent 900 and you have everything. Not with these cars. Start by reading the stickies in this section.
Old Jun 24, 2016 | 07:38 AM
I run mine @ -3.2PSI
i30krab
Jun 4, 2022 01:43 PM
QueensMAX
35
Apr 12, 2016 01:16 PM
Muswagon
Mar 28, 2016 07:45 PM
bocian
Mar 26, 2016 09:51 PM
mjf3232
Mar 26, 2016 12:05 AM
