Trunk grey cover
Old Aug 25, 2017 | 03:25 PM
Shannon and Ian's Avatar
Trunk grey cover
What is this called and how do I re install it?
Old Aug 25, 2017 | 03:34 PM
DennisMik's Avatar
That covers the rear seat center armrest hinge. Never took one off, so I've never installed one.
Old Aug 25, 2017 | 03:49 PM
CS_AR's Avatar
I've removed one to clean under it on the 99 I30 a few years ago. I had the rear seat back out of the car at the time..
Referencing Dennis post, it snaps on part of the seat back by the armrest.
Old Aug 25, 2017 | 11:38 PM
KP11520's Avatar
Looks like a pair of black pumps and a green bungee cord to me.
How to reinstall? That's a little too personal. LOL
Good luck getting it back in like nothing never happened!
Hopefully, you find a way without pulling the seat bottom and top!
Please let us know how it goes!
Old Aug 26, 2017 | 09:18 AM
I have not seen it in correctly to know how to reinstall it
Old Aug 26, 2017 | 10:46 AM
KP11520's Avatar
The pumps or the fabric trim piece? LOL
Below are pictures of where it goes. One end kind of flops into place and the other end is sandwiched into the plastic that divides the trunk and arm rest. Getting that plastic barrier out to reinstall the fabric end will most likely entail pulling the rear back seat bottom and then top to get it out to be dealt with.
Attached Thumbnails Trunk grey cover-resized_20170826_132834.jpeg   Trunk grey cover-resized_20170826_132731_003.jpeg   Trunk grey cover-resized_20170826_132819.jpeg
Old Aug 26, 2017 | 11:45 AM
KP11520's Avatar
Also.....
I remember when working behind the seat, I thought the bottom seat didn't really need to be removed to get the top/back out. It's 4 bolts. You can see two center bolts in the third picture above. The other two are at the lower outside corners (one each), 1.5 inches below the top bottom seat. Push it down to see. All 4 bolts are 10mm. You'll have to wrestle with the two outside bolts a bit to make this work, but nothing too difficult.
Hope this helps!
Old Aug 30, 2017 | 11:16 AM
thank you so much
