Will 19's fit my max?
Old Jan 21, 2001 | 05:36 PM
D-DOT's Avatar
I just wanted to know if 19's would fit a 3rd. gen max with stock susp.? If so, what width rim and what size tire should I go with?
Old Jan 21, 2001 | 06:10 PM
Tomo
YES. they will, my Q is is this a show car if not don't go bigger than 17 IMHO
Old Jan 21, 2001 | 06:17 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
The ride quality is gonna suck! it'll be really rough!! nm
Old Jan 21, 2001 | 06:40 PM
ngthing's Avatar
Re: The ride quality is gonna suck! it'll be really rough!! nm
Originally posted by DA-MAX
yup, but it'll look great ;p
Old Jan 21, 2001 | 07:28 PM
Bucktown's Avatar
in my opinion, the maxima body is too small to be riding on 19's. you need a bigger car, like an S 600 or an expedition
Old Jan 22, 2001 | 06:25 PM
flyry110's Avatar
if you're gonna put 19" rims on your max, you might as well put a lift kit on it and turn it into a rally car!
Old Jan 22, 2001 | 06:33 PM
SkyMax's Avatar
I had 19x8" wheels on my max with Suspension Technique springs so YES they will fit. My max looked 20 times better with the 19"s than with my 17"s. Tires for 19" wheels are around $150 - $300 each... yeah.. it's expensive. I wish I had pics of my max with the 19"s... I bought them before I drove down to the beach.. then after I got back from the beach I returned them! 19"s are for SHOW CARS not for daily drivers... I learned that from experience. The ride isn't that bad like most people would think. You really have to watch the road for bumps and potholes otherwise you might pop a tire. Also, be careful when going around turns.. cuz I swear I could feel my rim touching the ground when cornering.
Old Jan 23, 2001 | 09:57 PM
TwoMaxMan
I'm not sure why anyone would want 19" tires on their 3rd gen Max. Too expensive!
Check out tirerack.com for plus size compatability. My guess is that they would not recommend going over 17". Regardless, you do not want to increase your tire outside diameter. Width should not exceed whatever size came stock on the SE. Looking cool at the cost of not being able to turn the wheel without rubbing the wells is not cool at all.
Old Jan 23, 2001 | 10:18 PM
SkyMax's Avatar
So according to what you wrote, Tirerack doesn't want you to exceed 6.5" width? HAHAHAHHAHAHAHA... I think NOT! 17x8" wheels (my daily rims) are perfect for me and perform very well over stock wheels.. it provides excellent grip when cornering and helps keep traction slightly.
Back to the 19" wheels. You wrote "why anyone would want 19" tires on their 3rd gen Max" Well to answer that, I would have to say Try going to a car show with 19" wheels.. not only do the judges like that but so do some people who come to watch the show
Old Jan 24, 2001 | 11:21 AM
D-DOT's Avatar
Hey' Skymax did you have problems with the the wheels scrubing when you try to turn? note**(if I get the 19's I'm not going to drive or corner as hard as I do with my 17in. MOMO"s)
Old Jan 24, 2001 | 06:31 PM
SkyMax's Avatar
Had no problems scrubbing or problems with turning. They fit without rubbing the wheel well.. you just need lower profile tires which is a PITA while driving on rough roads. Did I mention I managed to warp all FOUR 19" wheels in a week?
Old Jan 24, 2001 | 06:39 PM
FAST4EN's Avatar
Warped em? Howd you do that? I've never touched anything with 17's even when I had a low tire (25psi instead of 44psi)....How'd you do that Nevin?
Old Jan 24, 2001 | 10:10 PM
TwoMaxMan
I appologize. Call me conservative. I guess that I've seen too many ruin the functionality of their cars with a poor tire selection. Although looking cool is important, I think that most folks use their Maximas as daily drivers-- not show vehicles. I may be wrong.
I checked Tirerack for their largest recomended size. Turns out that they go up to a 225/45-17 on a 7.5" wheel for a 92 SE. I may be a dope, but I think that selection would look pretty cool on a Max. And It would sure be nice to drive the car on lousy Pennsylvania roads.
Old Jan 24, 2001 | 10:22 PM
TwoMaxMan
Oops, I missed one. Tirerack goes up to a 225/40-18 on a 8" wheel for a 92 SE.
Old Jan 24, 2001 | 10:26 PM
SkyMax's Avatar
It's all good... Don't worry about it. Everyone is here to learn something. Your right, not everyone here uses their maxima as show cars. Most use them for daily drivers. People don't go out and buy 17" wheels just to look cool.. it also helps performance and handling. 19" wheels is an exception... with 19's you lose comfort and handling isn't improved much but apperance factor is greatly enhanced. I think 18" and beyond is the point where wheels lose their functionality.. 18" is kind of pushing the limit. I have had 15x6.5" wheels, 15x7" wheels, 16x7" wheels, 17x8" wheels, 18x8" wheels, and 19x8" wheels on my max before and I have driven with all these kinds of wheels. I am not saying that I am an expert, cuz I'm not. All I'm saying is that I have had experience with different types of wheels on my max.
P.S. Driving on PA roads is terrifying with 19" wheels.
Old Jul 18, 2018 | 11:05 PM
CMax03's Avatar
7.5" wide rim can have up to 235!
Old Jul 19, 2018 | 07:49 AM
ac max 92's Avatar
17 yr old thread ^
Old Jul 19, 2018 | 09:19 AM
chrome91's Avatar
thats a new record for a thread bump i think
Old Jul 20, 2018 | 04:35 AM
Hectic's Avatar
Yeah this thread is so old, it's from the days where it was physically possible for 1mm thick aluminum sheet metal to slice through steel and concrete structures.
Old Jul 22, 2018 | 08:40 AM
CMax03's Avatar
I had a question and I realize it's an old thread.... Again a 18 x 7.5 wheel will fit under a slightly (1.5") dropped 3rd gen right? If I don't get a response than I'll just test fit them...
Old Jul 26, 2018 | 08:22 PM
jordez1's Avatar
255/35-19 on 19x8.5 Rays Wheels
Wheels look flush with the fenders
Hi all,
I have two 3rd gen Maximas with 19x8.5 all the way around on both of my car. I personally like the way they look, but that’s my personal taste. I don’t do any hard driving or racing with my cars, Just weekend cars for cruising around West Houston area. By the way, streets in Houston are a lot better than many other cities in the US, which help a lot when you have an agresive set up like mine. (ST sway bars, Eibach springs, Tokico Struts). The only little problem that I have is when I turn to fast, front tire rubs a little at the upper outer part of the fender. But that’s when i turn too fast (35 and up mph). If you are going to drive agresive, don’t put 19s on it, 3rd gen Maximas are cars that turn heads now day not because they are fast or expensive, but because they are good looking cars period. Check out my pictures.
Old Jul 26, 2018 | 08:33 PM
jordez1's Avatar
1990 Maxima SE
1993 Maxima GXE 5 spds
1994 Sentra Coupe
1993 Maxima w/ 19x8.5 255/35-19
Old Jul 27, 2018 | 09:41 PM
CMax03's Avatar
That's a clean Maxima Bro! So that's looks like either stock or Eibach Springs! So my 18x7.5 is a cake walk!!! You ever had any wheels powder coated in H-town?
Old Jul 28, 2018 | 10:37 AM
jordez1's Avatar
CMax03,
Yes, springs are Eibach all the way around. I had never have any powder coated any of my wheels but I’m thinking about it. I know a shop that specialize in powder coating but I don’t want to spend a fortune, at least for now.
Old Jul 28, 2018 | 01:06 PM
CMax03's Avatar
Originally Posted by jordez1
CMax03,
SAB's is who I used for years if I had a bent rim or needed touchup...They're asking $250 ea for refinishing...I know I can do better than that....I love the wheels and my Wifey left the wheel cleaner on to long and it chemically burned 2 wheels...So I bought some new TSW's and they're 18 x 8 and look sexy and great on the 5.5th Gen...So I'll use these ACE wheels on the 3rd Gen...
Old Jul 28, 2018 | 02:55 PM
maximo018's Avatar
Damn that’s a clean 3rd gen on those Nismo edition Rays. Actually all 3 of them look good. I need to get back to work lol 😂
Old Dec 1, 2018 | 06:35 PM
GRNMAXDMON's Avatar
Damn, your Nissan family was like mine a little over 10 years ago. I had an 89 SE 5 speed with MOMO wheels along side my 93 GXE 5 speed and my sisters 94 Sentra 4 door 5 speed Limited Edition. Dumped my 89 but still got my 93 and my sister still has her Sentra stored away. Now we are a BMW family. And I use to have the 2nd Gen Infiniti G sedan as well. Keep up the good work on keeping them clean. I’m pretty much the only 3rd gen left in South Florida that is still daily driven.
Old Dec 6, 2018 | 10:35 AM
ac max 92's Avatar
Yes 18's are n.p. I actually had 245 wide with eibach's on mine which was between an eighth to a quarter of an inch from the rear shock and eventually went down to 235. 225 is whats recomended in 18's for the speedo. 18's look sharp in the wheel well but depending on the weight of the rim can be a little hard on the front end imo as so would 19's especially on lowering springs.
Old Dec 6, 2018 | 12:09 PM
ac max 92's Avatar
250 a rim seems really steep. I guess if you were only doing one and they're expensive rims but otherwise I would never re finish all 4 for what you could get a new set for.
Old Dec 16, 2018 | 12:22 PM
Tiniform's Avatar
We are keeping the maxima flags flying high in central Florida as well GRNMAXDON. Three here in the oOrlando area that are daily drivers..
maximagtr420
Apr 12, 2003 10:38 PM
jamesster
Mar 3, 2003 10:01 AM
2K1HoMax
May 21, 2002 08:04 AM
davidnajera
Feb 18, 2002 10:51 AM
JamesAvery
Jul 18, 2001 07:09 AM
