resistor mod question.......
Old Dec 22, 2003 | 02:50 AM
aw89maxSE's Avatar
Heard some stuff about a resistor mod that sounded interesting and this is basically what I got from it:
it is a resistor mod that keeps the knock sensor from changing the resistence based on the input it gets from the motor and then is sent to the ecu. The resistor mod just tricks the ecu into thinking everything is ok......and so on....
I've been told you can get them pretty cheap and can give a slight HP gain.
I'm just curious if anyone knows about this, a writeup and how to do it and also if it matters what gas you use.......
.......Just a curious guy here
Old Dec 22, 2003 | 05:21 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
don't se how an HP gain is possible...I think the point is to only make the ECU think the knock sensor is working if its broken(common problem for the VE)
Old Dec 22, 2003 | 01:37 PM
Matt93SE's Avatar
STFU n00b!
If the Knock sensor is dead, then the resistor mod is a band-aid until you can replace it. that's IT. It shouldn't be used for a permanent thing, and it won't give you any HP over a knock sensor that's working properly.
Old Dec 22, 2003 | 02:02 PM
aw89maxSE's Avatar
ok thanks for the info
knight_yyz
Nov 1, 2015 01:34 PM
REDinLV
Sep 28, 2015 12:31 AM
hez8813
Sep 27, 2015 08:37 AM
ballerchris510
17
Sep 23, 2015 08:46 PM
