Turbo Timer?
Old Nov 19, 2002 | 06:19 AM
Canuck's Avatar
Turbo Timer?
Hey,
How hard is it to install a turbo timer on a 99 maxima. I am just curious if it is any different than other cars. Especially with the imobalizer chip in the key?
If anyone has instructions that would be great.
Thanks for the info.
Old Nov 19, 2002 | 10:11 AM
delio's Avatar
Re: Turbo Timer?
Originally posted by Canuck
Hey,
I don't think on the 99's it should be a major issue, cause I think you need the key to get it running, not really keep it running. I have a timer in my 98 and it was a simple enough install. I can provide more info if you need it.
Old Nov 19, 2002 | 10:18 AM
Sprint's Avatar
not sure about 99 though..
this is the instructions from Harold (hlh0501) for the Blitz Turbo Timer.. all in all it took 7 mins.. very simple
The two black wires , just ground them on anything under the dash. you will need to find all your ignition wires, you can find that by pulling off that big cover where your knees are in the car, two screws and its off.. look for abundle of wires going to the key area.
BLITZ HARNESS ----> MAXIMA ignition harness wire
'95 - '98
red ----- > white w/ purple stripe
green ----> black w/ red stripe
blue -------> white w/ blue stripe
hope that helps, oh and the purple wire for the brake - needs to either be grounded, or, connect to brake wire (behind brake pedal - up under the dash) its red with green stripe.......
Old Nov 19, 2002 | 11:59 AM
Canuck's Avatar
So the question is are hte wire colours the same for 99s.
And which Turbo Timer should I get.
Old Nov 19, 2002 | 12:19 PM
delio's Avatar
The 99's are an odd bunch of cars. You can check a FSM or try
www.the12volt.com
You may have to register to see all the info you want. But it is well worth it. Freebie site.
-Del
Old Nov 19, 2002 | 12:33 PM
Canuck's Avatar
www.the12volt.com
-Del
They don't have any info for 99s
Old Nov 19, 2002 | 01:46 PM
delio's Avatar
I have a set of wiring diagrams for a 98... you may want to look at mine and see how your colors look in comparison, all the ignition wires are super easy to get to. Even Sprint's diagram should be a good starting point.
Your other option... go to a local stereo/alarm place and ask them for the printout of the wiring for when they do an Alarm install. That should have more than enough info.
Old Nov 19, 2002 | 02:53 PM
Canuck's Avatar
Do you think I could look at yours. They may be quite close. I might just see if Nigel will help me out with it since he has already don it to his 97.
Old Nov 26, 2002 | 10:07 PM
turbo97SE's Avatar
No problem, I can help! I am not sure about the chip in 99s though. Can probably figure it out! Email me!
Old Nov 26, 2002 | 10:24 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
The chip is only needed to start the car. Just like Sprite, I also have the DTT DCII. Check out Blitz's site for the 2 different TT's they offer.
Old Nov 26, 2002 | 10:31 PM
turbo97SE's Avatar
Cool, then it's cake!
Old Dec 1, 2002 | 12:56 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
Any of you guys run a turbo timer with a Clifford G4 alarm? Wiring that up isnt fun.
Old Dec 1, 2002 | 10:25 AM
turbo97SE's Avatar
Nope , but I have a Clifford Matrix (I think it is RS4). Probably have similar problems ... No time to wire it up yet.
Old Dec 1, 2002 | 09:42 PM
Turbo95Max's Avatar
on the G4 alarm if you want to arm your car while your turbo timer is on you have to bypass it. its tricky but not impossible.
Old Dec 1, 2002 | 10:16 PM
sx7r's Avatar
i have a 99 and my car waits a minute after i take the key out before shutting down.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
