Ive decided to go back NA
Psych
Well at least for a little while. My blower is leaking oil from the input shaft behind the pulley so it needs a rebuild. The V1 has ~70k on it now so it is ready for a rebuild, not to mention I spin it over its recomended limit
So, I took the blower and bracket off the car and removed the blower from the bracket. I had to put the bare bracket back on to to hold the alternator in place. I then put the factory belt back on, put my SC CAI filter on the crossover pipe, plugged the oil feed line, capped the oil return line, pinched shut the BOV vacume line and it runs just fine NA. Talk about quiet too, WOW!!! It is slow though
So this is a plus for the SC-vs-Turbo debate. The switch back took me 1.5hrs and the car runs just fine.
I wonder if I will get any more boost out of a refreshend blower?
So this is a plus for the SC-vs-Turbo debate. The switch back took me 1.5hrs and the car runs just fine.I wonder if I will get any more boost out of a refreshend blower?
Originally posted by SprintMax
i wonder if you will sell the blower when it comes back and go to the dark side
Re: Ive decided to go back NA
SuDZ
Re: Re: Ive decided to go back NA
Originally posted by SuDZ
Could the upcoming colder weather give you a bit more boost and make it hard to tell? Just curious...?
SuDZ
SuDZ
Re: Re: Re: Re: Ive decided to go back NA
I thought you were more down south.
SuDZ
SuDZ
Nope, But "there is no replacement for displacement" keeps poping up in my head
and most importantly becuase I will be very jealous if you get an F-body becuase I know it would be sweet.
Originally posted by Craig Mack
ahh...very nice. are you gonna swap engine blocks? [anti-jeffrey]in my quest for a throatier sound this may be in my future[/anti-jeffrey]
Originally posted by JAY25
You upgrading the blower? or just getting the $340 rebuild?
A 3.5L will make more power than a blower upgrade will give me, and I will probably be ok runing less boost.
Rebuild, I dont think the stock motor can reliably take more then 13.5psi. I hope some one proves me wrong
So have you been looking into what might be needed for the 3.5 to drop in? Do things match up somewhat well?
SuDZ
SuDZ
Yes & Yes
I dont want to type it out again so search please.
Originally posted by BriGuyMax yes...and not to mention it is an iron block, closed-deck motor that was designed to handle lots of boost.
I was confusing it with SR20DET or maybe it was the crack..
CorollaULEV
30
Aug 9, 2021 08:11 PM
