Are SAFC modules removable?
Old Dec 18, 2002 | 07:22 PM
Tanman's Avatar
Like stereos with detachable faceplates, can you disconnect the S-AFC unit and take it with you? I've never seen one in person so I don't know what kind of connectors they have.
I'd hate to leave my $300 S-AFC in the car where someone can steal it .
Old Dec 18, 2002 | 08:23 PM
delio's Avatar
Re: Are SAFC modules removable?
Not really unless you wanted to re-run the wiring harnesses everytime you plugged it back in.
Old Dec 19, 2002 | 06:20 AM
Tanman's Avatar
Re: Re: Are SAFC modules removable?
So the wiring harness doesn't plug into the back of the AFC? You have to disconnect the AFC from the ECU (or something else). Like on computer monitors where you can't disconnect the vga cable from the monitor, you have to disconnect it from the computer?
Old Dec 19, 2002 | 06:50 AM
PCGuRu2K's Avatar
Re: Re: Re: Are SAFC modules removable?
Well you can disconnect it but I wouldn't recommend it.. If you try to start your car without the ECU attached you'll check CEL because the AFC is hooked directly to your ecu... It happened to me before and I had to clear it. I have mines in the glove box.
Old Dec 19, 2002 | 06:59 AM
Tanman's Avatar
Re: Re: Re: Re: Are SAFC modules removable?
Yeah, I'd have to remember to reconnect it, but if I'm parking the car anywhere but my garage, I'd like to be able to unplug the afc and bring it with me, the same way I detach the faceplate of my stereo.
Old Dec 19, 2002 | 08:02 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Are SAFC modules removable?
Yeah that's fine... but you know how sometime it's late at night and you goto start your car up and forgot to plug in the afc.. CEL.. Just reminder to always plug in back in
Old Dec 19, 2002 | 09:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
Sorry for being such an ignorant NoObie but what's the S-AFC for?
Old Dec 19, 2002 | 09:34 AM
PCGuRu2K's Avatar
If your boosted then it's a good mod. You can adjust your A/F and allow it to run leaner which will give you more power...
Old Dec 19, 2002 | 10:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
OIC...
a couple of more questions
Is this another easy to install item?
I guess this requires dyno-testing?
Old Dec 19, 2002 | 10:17 AM
Tanman's Avatar
Re: Re: Re: Re: Re: Re: Are SAFC modules removable?
I always forget to plug my stereo face back in too . But with something like the S-AFC, I wouldn't forget .
Old Dec 19, 2002 | 10:24 AM
Tanman's Avatar
Yeah, it lets you adjust air-fuel ratio and such. For 5th gens with the SC and BOV, I've been told the AFC will correct the MAF readings that cause the car to idle funny. It costs like $250-300, so it's not cheap.
Old Dec 19, 2002 | 01:33 PM
PCGuRu2K's Avatar
OIC...
I would definitely recommend dyno testing.. Cuz you don't want to lean it out too much or BOOM!!
my03maxima
Jul 28, 2024 07:40 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
