Good Idea!!
Old Dec 28, 2002 | 01:31 PM
96shogunmax's Avatar
Good Idea!!
Why dont Jaime or another moderator put a sticky on the top with all the belt sizes with the different pulleys on the v1 and v2?
Just a thought
Old Dec 28, 2002 | 06:01 PM
BigDogJonx's Avatar
I was thinking they should put a rack of info on there. Like this for a V2 if they want to just copy and paste this stuff.
Gates belt sizes for V2 supercharger
3.60 to 3.33 - K060510
3.25 to 3.125 - K060705
3.00 to 2.87 - K060703 (00 would be a better fit, but Gates doesn't make that size)
FMU Disc Size
4:1 = 1.59"
6:1 = 1.85"
8:1 = 2.22"
10:1 = 2.47"
Spark plug sizes
NGK
Copper
BKR6E-11 1-step colder
BKR7E-11 2-step colder
Platinum
PFR6G-11 1-step
PFR7G-11 2-step
Gap is normally supposed to be .044", but you want to remove .004" for every 50 hp you add.
Fuel Pump
If you dont want to use the Stillen Aux pump and the Hobbs switch and its problems, I would recommend getting the Walbro GSS342 255lph fuel pump. Directions to install it is below by Stikya.
Aftermarket FP: Walbro GSS342 (High Pressure 255lph)
Why Needed?: If you want more than 65HP in nitrous, or do a major supercharger/turbo upgrade.
Price: It can be picked up for $95 shipped, look around on the net (i.e. ebay) for performance shops and e-mail them directly with an offer.
Performance Pontential: This pump will handle all of your upgrade needs pushing well over 100psi-enough for well over 400BHP.
Fittment Issues: This unit is the pump ONLY and will require the use of the stock pump housing and filter. It is nearly* a direct plug-in replacement for our stock pump.
*The pump has some small plastic spacer tabs on the top and bottom that need to be grinded off to fit inside our stock housing correclty. (Anyone with 2 minutes and a grinder can achieve this.)
You will also need get a new gas tank o-ring seal from your local Nissan dealer ($9).
Installation: (taken from Chunger's 4th gen. write-up)
PRELIMINARY STUFF :
WORK IN A WELL VENTILATED AREA!
·Remove the FUEL PUMP FUSE from the fuse box underneath the dash.
·Start the engine to use up the remaining fuel under pressure in the fuel line. Wait for engine to stall.
·Disconnect the GROUND CABLE from car battery.
·Reinstall fuel pump fuse back into fuse box.
·Open fuel door and take off gas cap to release air pressure in fuel tank.
OEM FUEL PUMP REMOVAL :
·Remove REAR SEAT CUSHION by pulling both RELEASE RINGS underneath.
·Remove the 3 bolts holding on the TOP COVER.
·Disconnect the 2 ELECTRICAL HARNESSES from the top.
·The top of the fuel tank is very DIRTY. To minimize the possibility of contaminating the fuel tank, CLEAN using brake cleaner. Wipe off excess and allow to dry.
·Disconnect both HOSE CLAMPS securing the 2 fuel lines leading to fuel tank. Have some rags handy as some fuel will come out of hoses.
·Remove the SIX 8mm BOLTS holding on the securing ring. Remove the RING and set aside.
·Slowly lift sender assembly and remove the WIRE HARNESS AND HOSE CLAMP underneath. Make note of the routing of the wiring harness to fuel pump as it will need to be reinstalled the same way. Remove ASSEMBLY and place in safe place.
***UPDATE*** Supposedly you can remove the whole fuel pump assembly by unlocking a tab located underneath the fuel pump outlet hose... I didn't do this but it could save you time instead of going through some of the steps below.... Here is a PHOTO from the Haynes manual...
·You will be able to see the fuel pump assembly underneath. Using a flat-head screwdriver, carefully, pry off the 2 LOCKING PORTIONS of the "basket" to FREE THE TOP HALF. On the other side of the "basket" are 2 hinges. It will "swing" off the hinges after the locks are freed. This part requires some time and finesse. Picture of TOP REMOVED.
·Carefully turn the FUEL PUMP AND PICKUP assembly counterclockwise about 90o and lift to remove. Note the position of the hose and pickup for later reassembly.
REINSTALLATION OF FUEL PUMP :
·COMPARE the OEM and Walbro fuel pump. Remove the short fuel hose from OEM pump and place it onto the Walbro pump in the same position.
·Carefully remove the pickup assembly RETAINER. Remove the pickup assemble. If pickup SCREEN is dirty, clean it. REINSTALL the pickup assembly onto the Walbro in the same position. Make sure the pickup is firmly attached to fuel pump!
·Carefully replace new Walbro/pickup assembly back into lower "basket" assembly. Start 90o and carefully turn clockwise to reposition the pickup underneath "basket". The lower portion of fuel pump needs to be positioned first, then you can push down slightly to get top portion to FIT SNUGLY. If it is not positioned correctly, the WHITE BRACKET COVER TOP will not snap back in correctly correctly. Place the top cover back on by starting with the hinged side. Do not force. You may have to reposition the pump.
·Replace old gas tank O-Ring with new O-Ring.
·Reposition sender assembly over gas tank by rotating it correctly over mounting holes to avoid kinking fuel hose to fuel pump. Reconnect the HARNESS AND FUEL LINE making sure wiring is routed the same way it was taken off earlier (away from float sender unit so as to not prevent it's proper operation).
·Slowly lower seat assembly over gas tank and O-Ring. There should be no resistance or fuel hose may be kinked underneath. Refasten/torque the SIX 8mm BOLTS to specifications over the RING bracket.
·Reconnect the 2 hoses and HOSE CLAMPS to assembly top. If you mistakenly swap these, the engine will not start.
·Reconnect the 2 ELECTRICAL HARNESSES.
·Refasten the TOP COVER.
·Replace REAR SEAT.
·Reconnect ground on car battery.
FINAL CHECK:
Start car temporarily then shut off engine. Note if there is any smell of gasoline. You may have to remove the top cover if hose clamps were not fastened tight enough.
If anyone got more to add feel free and we should get one of the moderators to sticky the info.
Dixit
Old Dec 28, 2002 | 06:09 PM
RBa's Avatar
RBa
FMU Disc Size
4:1 = 1.59"
6:1 = 1.85"
8:1 = 2.22"
10:1 = 2.47"
Spark plug sizes
NGK
Copper
Platinum
PFR6G-11 1-step
PFR7G-11 2-step
Fuel Pump
PRELIMINARY STUFF :
·Replace REAR SEAT.
FINAL CHECK:
Dixit
This answered alot of questions I was going to ask in the future..
Old Dec 28, 2002 | 08:37 PM
WizzaMax's Avatar
www.YourTheManNowDog.com
Old Dec 28, 2002 | 09:20 PM
BigDogJonx's Avatar
Good deal....... Glad it helped at least one person already.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
follyburr
Aug 7, 2015 09:50 PM
13Maximasv
Aug 7, 2015 10:56 AM
