Which Turbo is best for our Maximas?
Old Feb 6, 2003 | 05:51 PM
Ramius83
Ok, so there is a plethora of Turbo choices out there. For my birthday, my father bought me a T3/T4 Hybrid Turbo from www.turbochargers.com in anticipation that I will be going turbo in the next few months. But, I can return it for a full refund or trade it in for a better turbo. Now, my biggest question is, what is the optimum sized turbo to use in our Maximas? I know the T3/T4 has the best spool up rate, but other people are using the T3/TO4E combo and a T60 ball bearing turbo. What are the advantages and disadvantages to each turbo? What is best for dragging at the track? Etc etc etc. They all look the same to me, but what is best for our application? Thanks guys......
Old Feb 6, 2003 | 09:52 PM
Ramius83
Nevermind, I just got a GREAT explanation from Harold. Thanks guy.....
Old Feb 7, 2003 | 11:30 AM
CoOlKidS1979's Avatar
Could you pass that explanation on?
Old Feb 7, 2003 | 12:02 PM
Dreizehn's Avatar
Yes, please do...
Old Feb 7, 2003 | 01:25 PM
transportchef's Avatar
i was curious also
Old Feb 7, 2003 | 11:04 PM
sx7r's Avatar
me too
Old Feb 7, 2003 | 11:09 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Feb 10, 2003 | 06:40 AM
hlh0501's Avatar
I went through all the stuff that would take forever to type out, but basically whether he wants track car (giant turbo + nos), daily driver that boosts very early (hybrid turbo), etc.. Because you can go anywhere from a quick spooling t3/t4 making 3psi@1500, full boost at 2500rpm, to the awesome T3 stageIII special-order(making full boost around 3000-3300, and has incredible top end) turbo (my personal favorite!!) - this is not your standard t3 III btw, or even the route nigel chooses to go T4/60-1 with not much until 5000+... there are plenty of options out there, it is more of what you want it for, how much peak hp and when you want it spooled. There are a few other crazy combo's possible, that I will be testing out personally here soon as my built tranny is finished (couple weeks)
I have had a customer already switch turbo's from the t3/t4, to a larger size... he dynoed a little more of course, but the next day he switched back because he loved seeing the boost so early for normal driving..
Old Feb 10, 2003 | 09:22 AM
MAXIN's Avatar
Do you mean T3/T4? I was under the impression that the T3 (non hybrid) was too small for our displacement.... what are the specs of the turbo your referencing?
Old Feb 11, 2003 | 12:49 PM
hlh0501's Avatar
A standard T3 is too small for our engine. This is not a standard t3, and it also is not the stage I, stage ii, etc t3 like you would think, tricky as anything! It supports up to 650hp, and works beautifully with our car! I will try and get more info from my turbo supplier on them... they cost a few hundred more than a t3/t4, but could be worth it.. physically, the turbo I am talking about is larger than a t4 turbo, figure that out
Old Feb 11, 2003 | 03:31 PM
AphexX's Avatar
sounds good.
but do any of the turbos go good with an I30?
also if u could tell me.
what would be good for a kid driver. here is how i describe kid: (daily driver, that likes to fool around with buddies and race for fun) which turbo wuld be most ideal for this? also about how much wuld it cost?
thanks in advance
JP
Old Feb 11, 2003 | 05:10 PM
hlh0501's Avatar
Originally posted by AphexX
sounds good.
thanks in advance
JP
All of the stuff I said earlier about maximas is the exact same for your I30... vq30's, same setup As far as cost, www.hlh0501.com for the kit pricing (will be changing shortly).. that includes a t3/t4 which is awesome for what you were just talking about, daily driving, having boost in the lower rpms for normal driving, etc...that is how i decided on the turbo I am currently running, not for absolute peak hp for track only use, I wanted something I could daily drive and love seeing boost constantly.. it's up to what you like and how you will be driving decides what turbo we use
Old Feb 11, 2003 | 05:31 PM
Sprint's Avatar
so how much did this customer dyno?
Old Feb 12, 2003 | 07:29 AM
turbo97SE's Avatar
Well, I have yet to see any dynos from anyone running T3/TO4 B or E. Even though the big power doesn't come on until later I think it is more than adequate even lower down. I will hopefully be trying out a new experimental turbo soon that is fully spooled at around 2500 rpm. If someone has posted dynoes for a T3/T4, that's great, I would love to compare. Perhaps I missed it since I don't visit the boards so often.
It's true I have to keep my revs up when I race, 4000+ rpm gives me more than enough torque and power. I don't want to be boosting when I am cruising on the highway (something I need to do everyday). With this new turbo, that's what I am afraid of, but if it is under light load, it shouldn't be too bad.
Old Feb 12, 2003 | 01:54 PM
Swafford98's Avatar
will this be going up or down??
Old Feb 12, 2003 | 02:21 PM
Lets see some more dynos so I can make up my mind on what turbo I want to get when I order my kit
MAXSE5SPD
Aug 23, 2015 12:06 PM
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
