Can I tune fuel pressure w/S-AFC?
Old May 14, 2003 | 11:34 AM
robocop199's Avatar
I have the walbro fuel pump installed on my 99 S/C max and i'm pretty sure its running rich. I want to know if i can lower my fuel pressure with just the S-AFC? Instead of buying both the SARD FPR and S-AFC, if not, then would I be ok running just the S-AFC for a little. I really want to dyno tune my car but money is a little tight and I'd rather just by the S-AFC for now. Thanks for any help
Old May 14, 2003 | 11:41 AM
mtrai760's Avatar
'Trynna' is not a word
Nope, the S-AFC won't affect fuel pressure. You can use the SAFC to help adjust your a/f ratio, but you must spend time on the dyno to tune it. The afc adjust the amount of fuel being delivered, not the pressure it is delivered at. An aftermarket fpr would be a lot cheaper than buying a safc and the associated dyno time. Hope this helps.
Old May 14, 2003 | 11:48 AM
robocop199's Avatar
Yes that definitely helps, thanks
Old May 14, 2003 | 12:43 PM
JAY25's Avatar
No you use the SAFC to add fuel(richen fuel mixture) or subtract(lean) fuel mixture. You use the Vortech FMU to adjust fuel pressure by changing discs, or you can adjust it with that SARD or Cartech FMU.
Old May 14, 2003 | 01:06 PM
Stephen Max's Avatar
Just a footnote to add to what you're correctly saying, the SAFC adds or subtracts fuel by controlling injector pulse width.
A question I have (sorry to ***** up your post, but it's related) is does the SAFC affect afr during partial throttle acceleration when the ecu is in closed loop mode and is making adjustments based on oxygen sensor input? I'm thinking it does, but I remember reading about some doubts about this.
Old May 14, 2003 | 07:14 PM
mtrai760's Avatar
Nope. The SAFC can only be set to work above 50% throttle, or else the ECU will eventually cancel it out. Kinda sucks.
Old May 15, 2003 | 08:02 PM
delio's Avatar
39% throttle
Old May 16, 2003 | 05:57 AM
Originally posted by delio
39% throttle
Not sure what you're saying here.
Old May 16, 2003 | 06:00 AM
mzmtg's Avatar
Minister of Silly Walks
The SAFC should be set to work above 39% throttle, not necessarily 50%.
Old May 16, 2003 | 06:50 AM
Oh, that's right, I forgot. I had a senior citizen moment, I guess.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
