New
Old May 19, 2003 | 12:55 AM
danthediablo19's Avatar
New
Im thinking of getting a SC..NEED HELP AND INFORMATION???? what do i need after i purchase the sc? if i have a auto and gonna purchase the level 10 auto trans and tran cooler and vb mod also...thanks..IM new at this SC.Thanks and hope i get lots of information about it..thanks
Old May 19, 2003 | 04:33 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Tranny cooler is a must, a valvebody would help....
If you're running the 6 lbs of boost with the regular pulley, get a good set of guages to monitor your car with... www.summitracing.com
The more boost you plan on running, the more parts/ money we're talking.
Old May 19, 2003 | 01:26 PM
wanted to run 10 lbs of boost..What are the parts would i hvae to get?...um whats the best way to upgrade my fuel system?
Old May 19, 2003 | 02:59 PM
[maxi-overdose]'s Avatar
are you 4th gen or 5th gen? if you are 4th gen....you might want to look into larger injectors for high boost. Otherwise, the aux pump comes with the kit will be sufficient to deliver.
scroll down th is forum and check out stuff like gauges, etc.
EGT is a must. IMO
Old May 19, 2003 | 05:13 PM
turbomax97's Avatar
recipe for 10 lbs boost
oem injectors are fine
8:1 fmu disc if using vortech
1 step colder plugs if necessary
EGT guage tapped into exhaust manifold
Fuel Pressure guage
max'n out's Avatar
do not go to level 10
Old May 21, 2003 | 11:21 PM
GoldenGlory
YOUR TRANSMISSION
Old May 22, 2003 | 03:11 PM
qnpark8282's Avatar
Originally posted by GoldenGlory
YOUR TRANSMISSION
hhahhahahahahha. you need a 5speed tranny or you'll end up like will
Old May 22, 2003 | 10:32 PM
GoldenGlory
Q the caps. you owe me one, ill buy the other 3 from you.
you got the screws and all right?
call me
Old May 23, 2003 | 07:49 AM
PCGuRu2K's Avatar
Even with a 5spd tranny... Too much boost and you'll end up like me
Old May 27, 2003 | 10:33 PM
GoldenGlory
your juss plain nutz
Old May 29, 2003 | 08:41 PM
LatinMax's Avatar
Why? I fugured that if and when I blew my auto tranny i would do a Level 10 or Maximum said that they could make a bullet proof tranny.
I don't want to go 5 speed.
Tell me what you know.
Old May 29, 2003 | 08:56 PM
max'n out's Avatar
I know level 10 is not what it's cracked up to be, they use paper clutches and they are not all that...It's a waste of money...I didn't say go 5 speed I dont' recomend that either. I recomend finding a shop that is used to doing "performance" auto trannys, your gonna need to search around I dont' know where you are, but there are places. I'm the only guy to my knowledge on here that has a fully custom auto, and i can tell you it's far stronger than a 5 speed, and shifts better than a 5 speed so I'm not talking out of my butt.
Old May 29, 2003 | 08:59 PM
LatinMax's Avatar
I am in Texas. I see you are in NC. How much did it cost you.
I figure a well built auto tranny would shift faster than most people can shift a 5 speed under boost.
Old May 29, 2003 | 09:05 PM
max'n out's Avatar
I was asked not to say, as it was a hookup price. I didn't have it done in NC though it was MD, I will say it's no more than a 5 speed swap and far better and your right it shifts faster than you can snap your fingers. If you have specific q's feel free to email me or im me over aol.
