Do you think that boosting an 100K car is good?
Old Jul 11, 2003 | 01:07 AM
Taken2DaMax's Avatar
I was very interested in purchasing a turbo or supercharger for my 1997 maxima but i am very hesitant because my car has about 120k.I ride the maxima like a daily car with a couple of street races a month. The car is in great condition with no problems. Do you think that putting a boost like that would ruin my car since it has so many miles? I just wanted to know what you guys thought about this.
Old Jul 11, 2003 | 05:17 AM
PCGuRu2K's Avatar
Just do a compression test. If all tests well then go for boost It's just you
Old Jul 11, 2003 | 08:13 AM
[maxi-overdose]'s Avatar
just FYI: Benblanco218 had a very high milage motor and he supercharged it......it did really well on dyno and gave a really high whp, 278whp/256lb IIRC. He has a 4th gen and he has more whp than my 5th gen (we both have same tranny).
But I heard him recenetly blew his head gasket...
Old Jul 11, 2003 | 09:04 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I had 125,000 miles on my 97 when I turbo'd it. I am now at 128,000 and counting.
Compression test is the best way to tell if your motor is ok.
Old Jul 11, 2003 | 12:29 PM
Stephen Max's Avatar
Re: Do you think that boosting an 100K car is good?
I hope not. I installed my SC when my car had 120k miles on it. After 12000 miles the compression is unchanged and it still idles as smooth as before. So the engine is handling it well.
With a high mileage car you may have problems with old axles, cv joints, clutch or auto tranny, control arm bushings, etc. now having to cope with the additional power you're subjecting them to. In my case I did a tranny conversion prior to adding the SC, so I haven't had any problems there, either.
Old Jul 11, 2003 | 04:01 PM
where would you go to get a compression test? And what does that test do?
Old Jul 11, 2003 | 07:56 PM
subs1000w's Avatar
it tests what kind of condition the piston, rings, valves are in, i would think any auto shop would be able to do it just call around
Old Jul 11, 2003 | 09:30 PM
Craig Mack's Avatar
All YOUR grammer belong to me
You can also tell if your compression is bad if you have a rocky idle, your car has poor acceleration, or your breather valve is leaking oil.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
cheftoo
Aug 20, 2015 05:17 AM
