Do I need to grind the plate for a 3.33" pully?
Originally posted by Chunger
Don't think so but i'd do it anyways... cuz
You won't be happy with JUST a 3.33" in no time at all
That was my plan anyways...just wondering if it had to be done incase I didn't get to it tonight.
I think 3.125 or smaller gives a big diff on butt dyno. you boost faster with smaller pulleys too, little tap of gas pedal you are already in 0 on your boost gauge.
Sounds painful!
I hacked off more than needed too:
Sounds painful!
Should I just cut it off, or is it needed to help support the supercharger as well?
Obviously YOU don't need it
If this post is completely removed, I wonder if it allows for a belt change without removing the S/C assembly... You'd probably still need to grind open that big hole where the center of the S/C pulley goes though.
Nice "side effect" of the procedure.
knight_yyz
Nov 1, 2015 01:34 PM
