INJECTORS: VQ30DE vs. VQ30DE-K vs. VQ35DE?
Old Oct 21, 2003 | 11:28 AM
  #121
SR20DEN's Avatar
VQ Wizard
Originally Posted by IceY2K1
*UPDATE*
RC Engineering just got back to me and CONFIRMED the 350z injector part number is FBJC100, which is the SAME as the '00-'01 injector.
They stated the 350z injector flowed 295cc/min, but didn't specify if that's at 3bar or 3.5bar.
I'm pretty sure it's 3bar, so ORDER AWAY!!!!!!
That would certainly be at 3.0 bar and proves what I have been saying all along.
This also gives VQ35 owners (AND 3rd gen Eclipse) a cheap/small upgrade path.
Old Oct 21, 2003 | 11:35 AM
  #122
SR20DEN's Avatar
VQ Wizard
Actually, they stated the 350z injector part number is 3660 2824 FBJC100.
All I can see on the -K injector is FBJC100 000 0x29.
I don't *THINK* that's a concern, but I'd still like to get a -K injector sent into RC Engineering to confirm the flow rate.
http://www.poweredbynissan.com/image.../injector1.jpg
And IIRC the Maxima VQ35 injectors are FBJC101
Old Oct 21, 2003 | 11:43 AM
  #123
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
And that PROVES what I've been saying all along.
The VQ30DE-K and VQ35DE in the 350z share the same injector and the VQ35DE in the Maxima doesn't.
Yes, the VQ35 Maxima injector is a FBJC101.
Old Oct 21, 2003 | 11:44 AM
  #124
IceY2K1's Avatar
You do realize that's BigDogJonx picture a couple pages earlier, right?
Old Oct 21, 2003 | 11:49 AM
  #125
IceY2K1's Avatar
Hmmmnnn...makes me wonder why Nissan would downgrade from 295cc->270cc injector for the "255hp" VQ35 in the Maxima, yet raise fuel pressure to compensate. Cheaper probably.
Old Oct 21, 2003 | 11:52 AM
  #126
SR20DEN's Avatar
VQ Wizard
He snapped those pictures upon my request several months back. So yes I know where they came from.
Old Oct 21, 2003 | 11:53 AM
  #127
SR20DEN's Avatar
VQ Wizard
But you also were trying to claim it ws a 240cc injector which is what i have been disputing all along.
Old Oct 21, 2003 | 11:57 AM
  #128
IceY2K1's Avatar
"So, my question is WHAT injectors fit a VQ30DE-K? Also, can someone explain what's the difference between the different Maxima injectors physically? Is there ANYthing similar physically that *might* fit, but offers a higher flow rate?"
No...I was claiming they weren't 240cc, since they are the same injectors used in the 350z, which as you've stated wouldn't make sense for a 287hp car even if it's pushing 3.5bar.
My point from the start is to be able to find a compatible higher flowing injector NOT what our stock injectors flow.
Now we know boosted guys have an alternative to CUSTOM high flow injectors.
Old Oct 21, 2003 | 12:03 PM
  #129
IceY2K1's Avatar
BTW SR20DEN....did you swap the digits here:
SR infectors are 259cc @ 3.0 bar. The 350Z having infectors that small would make no sense even at 3.5 bar.
According to DAVEB, the SR20 engines use the same injector.
Old Oct 21, 2003 | 12:04 PM
  #130
SR20DEN's Avatar
VQ Wizard
What alternative are you talking about? The same injectors they already have? How is that an alternative?
As I stated earlier, one of the best alternatives is the '03 Cobra 39# injectors for a measly $40 each plus the cost of wiring.
Old Oct 21, 2003 | 12:07 PM
  #131
SR20DEN's Avatar
VQ Wizard
The earlier model years were 259cc saturated. So apparently at some point they changed over to the 295cc top feed.
Old Oct 21, 2003 | 12:08 PM
  #132
IceY2K1's Avatar
The RC Engineering 370cc and 440cc or the PE 380cc and 510cc.
If you can confirm the '03 Cobra 39# injectors fit/work that's even better.
Old Oct 21, 2003 | 12:10 PM
  #133
IceY2K1's Avatar
I think DAVEB recanted that.
He says the latest parts CD had a different part number, so I'm not sure.
Old Oct 21, 2003 | 03:26 PM
  #134
SR20DEN's Avatar
VQ Wizard
The 370cc and 440cc injectors are the saturated ones and will not fit.
Old Oct 21, 2003 | 04:29 PM
  #135
IceY2K1's Avatar
Greddy's 350z is running the 440cc.
Old Oct 21, 2003 | 05:31 PM
  #136
Deac's Avatar
Hmmmm...
Let me get this straight.... The 350Z injector (FBJC100) should be a direct fit for 00-01? If thats so... all the hop-up injectors should fit also no? I heard they have up 550cc for the 350z now??? I'm asking because I know I need injectors badly but I dont know much about how they work or which ones I should get. I have the e-manage and I'd love to do the injector upgrade on it but I have no injectors yet. I'm ready to spend if the injector will fit man... let me know!!
Deac
Old Oct 21, 2003 | 06:01 PM
  #137
IceY2K1's Avatar
Deac -
Everything I've seen, read, been told, says the 350z and our cars use the same injectors, therefore ANY of the 350z high flow injectors should fit. However, for the RC Engineering injectors, the 350z supposedly requires a pigtail that is additional and must be spliced. I've read Power Enterprises specializes in drop-in injectors that require no modifications, however I've not confirmed that. I've emailed these guys asking that: http://www.rbmotoring.com/sales.html.
The contact I've found for RC Engineering injectors is "ForcedInduction" on the www.350z.com forum. His website is www.SuperchargersOnline.com. His thread here http://www.my350z.com/forum/showthre...light=injector states:
Originally posted by ForceInduction
btw... we can get a hold of the RC Injectors for you guys/gals.
440cc - $80.00 each
370cc - $79.00 each
RC said these fit pretty tight and they will come with the cushions. You will need to get pigtails for them which run $9.00 each too.
You're PIONEERING here Deac, so lots of this is unknown. I've *READ* the Greddy 350Z runs 440cc with the eManage, but don't know if that's daily driven and streetable. I'm not sure if 370cc/380cc injectors can be controlled by the stock ECU with an adjustable FPR like Mardi did, however 4th gens. *SUPPOSEDLY* run 25Xcc injectors and he successfully ran 370cc injectors with an adjustable FPR for awhile until he went with the JWT ECU.
I'm NOT going to say with confidence, whether the injectors are going to work or not, since I don't know and I don't want to be held responsible, ie blamed. I'd buy ONE injector FIRST to verify everything fits/connects properly if you're still going to be down for awhile, but that's my pessimistic side talking.
I *THINK* I understand how the eManage works with the stock ECU and I'd be hesitant to run any injectors larger then 3XXcc.
Deac
Old Oct 22, 2003 | 08:46 PM
  #138
Deac's Avatar
Pic/Comparison
I *THINK* I understand how the eManage works with the stock ECU and I'd be hesitant to run any injectors larger then 3XXcc.[/QUOTE]
Wheres that pic of the 2k-2k1 injector side by side w/the 350z injector? I'm inclined to buy a 440cc 350z injector from RC but I want to see how they look again...
Deac
Old Oct 22, 2003 | 08:47 PM
  #139
Deac's Avatar
Pic/Comparison
Deac
Old Oct 24, 2003 | 04:55 PM
  #140
IceY2K1's Avatar
Just got an email back from RB Motoring on the Power Enterprise 380cc 350z injectors!
Dixit, Deac, and I'm sure Kevina...go in on these for $831/set.
List price on the injectors is $180.00 each.
Jobber on that is: $153.90 each.
I'll give you jobber on it. Get your group buy going, and I'll give
you
more off....let's say: $138.51 each.
Victor R. Reyes
RB Motoring Co.
(626) 961-9213 · FAX (626) 961-7803
AIM: RBMotoring
www.rbmotoring.com
Old Oct 24, 2003 | 05:20 PM
  #141
Deac's Avatar
Why would we go for these at a much higher price than go for the RC 440 cc ones for $80 each? Is there a difference? They should be the same part number/type of injector right?
Deac
Old Oct 24, 2003 | 05:59 PM
  #142
IceY2K1's Avatar
Yes...*SUPPOSEDLY* the RC Engineering injectors run 4 or so holes in the pintle, where as the PEs run 10 or so like stock or other high quality injectors. More holes means better fuel atomization and I'm assuming this will help idle and fuel distribution for lower base idle fuel pressures.
Another thing is that the RC Engineering injectors require pigtails to be spliced, but the PEs *SUPPOSEDLY* don't. Probably not a big deal for you, since you're splicing for the eManage anyways.
Another *RUMOR* is that the RC Engineering injectors are supposedly rebuilt Lucas injectors and PEs are top quality Denzos like the OEMs typically use. PEs claim "drop in" OEM replacements, while RC Engineerings are a "tight fit", but apparently work.
PEs are very popular in Japan, but RC Engineering injectors get the job done for roughly half the price. Your guys choice. PE does make 510cc injectors, but I'm not sure if the price is different.
Deac
Old Oct 28, 2003 | 09:02 PM
  #143
IceY2K1's Avatar
Deac -
I may have been FOS on those rumors.
Check out the link in this thread for some GOOD info:
http://forums.maxima.org/showthread....92#post2446192
Deac
Old Oct 31, 2003 | 11:14 AM
  #144
nismology's Avatar
I know this is OT but at what fuel pressure levels should somebody be worried about injector lockup?? BTW this is on a DE-K with 3.33 pulley and 8:1 disk untuned.
Old Oct 31, 2003 | 11:46 AM
  #145
IceY2K1's Avatar
Nobody knows for sure, since nobody has sent one of our injectors to RC Engineering to be tested.
They can determine that.
Old Nov 4, 2003 | 05:56 AM
  #146
Deac's Avatar
Deac -
I'm going to the junkyard today on my day off to get some injectors off a junked 00-01... I'll make arrangements to send them to RC and answer the question once and for all!! Wish me luck!!
Deac
Old Nov 4, 2003 | 06:09 AM
  #147
SR20DEN's Avatar
VQ Wizard
Deac
Make sure you have them flow the injector(s) at 3.0 bar AND 3.5 bar. We need to sticky this as standard procedure.
Old Nov 4, 2003 | 08:21 AM
  #148
IceY2K1's Avatar
3.5 bar would be nice!
Also, they can determine minimum and MAXimum fuel pressures that the injector can handle. These tests would be VERY valueable to know for people running bigger injectors and pushing stock injectors with a FMU:
"...will provide a computer generated print out over varying RPM, pressures, and pulse widths, in color, similar to a dyno test graphic report. This will provide a graphic depiction of min/max Duty Cycle failures and pulse to pulse variances."
AND
"We test injectors in 8 different procedures and at varying pulse widths with pressures ranging from 43.5 PSI for the standard test, up to 100 PSI for leakage and electronic evaluation. If an injector leaks or gets weak at the higher pressures we see this on the oscilloscope and the digital flow meter. If the pattern format starts to defuse, and produce out of range coalescence, the injector is of course discarded. We analyze this with a strobe light and laser beam to measure width and droplet size. If the injector passes the leak test we return to 43.5 P.S.I. and check for minimum response pulse width."
Ask how much those procedures COST and we'll get some people to chip in.
Thanks!
Deac
Old Nov 4, 2003 | 04:30 PM
  #149
IceY2K1's Avatar
Back yet?
Deac
Old Nov 4, 2003 | 04:46 PM
  #150
JeffesonM's Avatar
living out of a maxima...
Ice, you are relentless!
Old Nov 5, 2003 | 11:13 AM
  #151
IceY2K1's Avatar
DAyyyyyymn!
That's one LOOOOOOOOONG day off.
*bizump*
Old Nov 5, 2003 | 06:48 PM
  #152
Deac's Avatar
Back yet?
still working on it... I'll be sure to post when theres something interesting to post.
Old Nov 6, 2003 | 12:09 PM
  #153
IceY2K1's Avatar
Interesting little tid bit in my Modified MAG mag(great pics!) about the JIC 350Z running an ATI SC.
With only an ATI fuel pump and FPR, the STOCK injectors are supporting 380whp@9psi.
Old Nov 6, 2003 | 12:41 PM
  #154
spirilis's Avatar
This is all really good stuff... I don't know jack about fuel systems ... one article referenced in a previous post (talks about saturation vs. peak-and-hold) was quite informative; does anyone have some more sites that go into great detail about fuel systems, fuel injection, etc.?
I'm not thinking of boost anytime soon, but I wanna learn
Old Jun 25, 2008 | 11:06 AM
  #155
adiadrian's Avatar
Hello, I am new to this forum and please do not respond that I am in the wrong forum, as you are a forum where I have found some information. I have a 2003 Murano with the VQ35 engine exported from Canada to Europe where I am now. Unfortunately one fuel injector FBJC101 is clogged up, but here in Europe I can not get them. Are there BOSCH injectors that I can use for my engine?
Old Jun 25, 2008 | 11:12 AM
  #156
kzoosho's Avatar
Are you trying to replace just one? If so just go to ebay and youl find them all over.
Old Jun 25, 2008 | 01:11 PM
  #157
adiadrian's Avatar
On Ebay I have not found one single FBJC101 injector. Nevertheless I would like to replace all of them with something from BOSCH, as I can get BOSCH injector here without any problem. UNISIA JECS are very problematic to get in Europe
Old Jun 25, 2008 | 01:21 PM
  #158
kzoosho's Avatar
You can try my350z.com . They may have more info on the 3.5 injectors for you.
Old Jun 25, 2008 | 01:22 PM
  #159
NmexMAX's Avatar
dot dot dot ...
I got 6 if you want to buy them.
IIRC, stock are Bosch.
http://forums.maxima.org/showpost.ph...4&postcount=35
IIRC's Z33 units are FBJC100's.
Old Jun 25, 2008 | 01:24 PM
  #160
kzoosho's Avatar
I know you would know better than me.
