THIS is the difference between a Turbo and a Supercharger
Old Sep 6, 2003 | 09:24 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I copied this from Y2KEVSE. I added some things to the graph to help show area under the curve
THIS IS Y2KEVSE'S DYNO GRAPH. KEV IF YOU MIND I WILL TAKE THIS POST DOWN. YOU POSTED ALL THIS INFORMATION. I JUST PUT IT WHERE EVERYONE COULD SEE IT
Originally Posted by Y2KevSE
If you're looking at dyno numbers, the biggest difference between a turbocharged and supercharged (centrifugal) Max is the area under the hp and torque curve. Since the turbo makes peaks boost faster (meaning it will probably flow more air into the engine), a TC'ed car will pull away from the SC'ed quicker.
You want another comparison?
I am not putting down Matt or his accomplishments... this is only an example. Only respect for Matt
MardiGrasMax makes 379.78 whp and 320.43 torque at 15 psi on his SC (no nitrous). I make 317.3 whp and 314.4 torque at 10 psi.
Let's plot the hp and torque numbers
Code:
             Approximate hp and torque
RPM          Matt          Me
2500         95/190        85/180
3000         120/210       120/200
3500         160/235       145/220
4000         200/260       195/255
4500         245/285       240/305
5000         295/305       290/310
5500         325/310       305/295
6000         370/320       317/275
6500         N/A           315/250
You see how close the numbers are all the way up to 5500? Close race huh? But Matt will kick my butt after 5500.
Take a look at the dyno graph between the two different setups I had:
- SC with 2.87" pulley pushing out 11 psi
- TC with T4 ceramic ball-bearing turbo pushing out 10 psi
I have made marks on the graph.. it has NOT changed
Edit: Made two changes, which are bolded.
Old Sep 6, 2003 | 11:23 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Sep 6, 2003 | 11:47 AM
max'n out's Avatar
That fuel curve sucks.
Old Sep 6, 2003 | 12:02 PM
Bags's Avatar
No finger pointing craigy....
just the picture proof of the differences..
Old Sep 6, 2003 | 01:18 PM
Craig Mack's Avatar
What i'm surprised at is Matts V1 supercharger, which makes significantly more torque under 4000rpm at 15psi than Kevish's turbo at 10psi. At 4000rpm Matt is making 50tq more than Kevin.
Quick Spoolin', "torquey" turbo gets OwNeD by the "torqueless" lag-charger.
Old Sep 6, 2003 | 01:57 PM
Bags's Avatar
now.. I never said the SC was TQless.. kev actually said the 5th gen were TQless wonders due to the VI...
now when the VI is applied to a 4th gen we become TQ less wonders as well.
You said it yourself " What i'm surprised at is Matts V1 supercharger, which makes significantly more torque under 4000rpm at 15psi than Kevish's turbo at 10psi " the Turbo, PSI for PSI will produce MORE TQ than a SC. ( IN A MAXIMA )
And yes mardi owns all of us... and he will REALLY own ALL of us when his current project gets back to him
Old Sep 6, 2003 | 01:58 PM
Bags's Avatar
and BTW I did not put this out there to cause any hate or discontent.. just to show the MAIN power difference.
Not better, not worse.. just different
Old Sep 6, 2003 | 02:34 PM
MoDiddy's Avatar
Im dont know much about boost, so dont hate, but which one are you saying is better? Im guessing the SC'er
Old Sep 6, 2003 | 02:55 PM
Bags's Avatar
Well what do YOU want from your car?
When you can aswer what goals you want then you can answer your own question..
for example do you want 400 WHP?
In my opinion , in a maxima, I think the turbo is your best option. Takes more research, but the benfits are better
Old Sep 6, 2003 | 05:14 PM
Craig Mack's Avatar
True True, which is why I will never buy a VI. I'd rather not lose ~10tq under 4000rpm.
True, but how much torque is kevinGee making per PSI? He cant be making much more than 10tq per psi, so even if they were at the same PSI, he probubly wouldn't have a terribly greater amount of TQ.
Turbo kits definatally seem to be breaking a lot of things, but the power seems to be rewarding. The SC is a very simple setup though, and can still deliver brutal power if your in the right power band.
Old Sep 6, 2003 | 05:50 PM
ereet's Avatar
Turbo kits breaking things? I haven't heard of anything being broken other than the turbo kit itself, with the exception of Redmax's (which is a custommaxima kit ....) What's been broken?
Old Sep 6, 2003 | 06:51 PM
Bags's Avatar
check this forum for my thread about my tranny..
Broken, not now... but it was not working correctly.
I put that on the VI and 8 PSI of boost, thus to much acceleration and hp/tq for the transmission to shft up into anoother gear.
and there will be broken parts VERY soon by other members.. as soon as they start "testing" the waters.
Our cars were not built for 350 + WHP/TQ
Something is bound to give sooner or later...
But that is the fun of it
Old Sep 6, 2003 | 07:00 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
If you guys want a "psi" to "psi" comparision (which won't be an accurate comparison) that makes similar horsepower, take jay25's dyno graph and compare it to mine.
Code:
RPM          Jaime           Me
2500         80/175         85/180
3000         110/185       120/200
3500         135/185       145/220
4000         150/200       195/255<~~~255
4500         185/215       260/305
5000         230/240       290/310
5500         255/250       305/295
6000         295/260       317/275<~~~275
6500         321/260       315/250
Old Sep 6, 2003 | 07:09 PM
Y2KevSE's Avatar
Of course... no disrespect to Jaime. Just trying to do a comparison here.
Old Sep 6, 2003 | 07:42 PM
Bags's Avatar
Code:
RPM          Jaime           Me
2500         80/175         85/180
That is why I used YOUR dyno that you were nice enough to post
That was as close of a comparison as one could ask for.. the only way it could have been better was if you were at 11 PSI.. but life and examples aren't perfect.
and jay knows we love him.. he still kicks my ****
EDIT: i just threw in your qoute with it .. less work for me
Old Sep 9, 2003 | 02:54 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nice...
This is a little easier to see IMO.
It lost the color in the PDF converison, but hopefully the attachment works.
Old Sep 9, 2003 | 03:08 PM
JAY25's Avatar
those numbers are higher then my baggs, why is it that you fall off a bit close to redline?
isnt the MEVI suppose to pick that up? I am lost
Old Sep 9, 2003 | 03:41 PM
Stephen Max's Avatar
That is the downside of a turbo compared to a supercharger. You see that high rpm power drop in all the dyno plots I have seen for turbocharged Maximas. A SC will continue to make increasing power up to whatever redline you choose. A turbo that is chosen for minimum boost threshold and lag time will eventually run out of pumping power in a high revving engine. If you pick a bigger turbo that does not run out of breath, you increase the lag time and the boost threshold.
In general, a turbocharged car is best run at lower rpm and shifted earlier than a supercharged car, which is always shifted at redline for maximum acceleration. It should be interesting to compare power under the curve for a turbo'd Maxima compared to a SC'ed Maxima with, say, a 7200 rpm redline.
Old Sep 9, 2003 | 03:48 PM
96sleeper's Avatar
That is an awesome graph. It really shows what is meant by area under the curve. Jay makes more peak power, but in a race with all other things equal, keving's car is alot faster. The 5th gen does weigh a little more, but I don't think it would matter.
Old Sep 9, 2003 | 03:55 PM
JAY25's Avatar
see how steep it is in the middle adios keving slow down let me catch up aint no way Ill catch up even if he falls off at 5K, all I would see is his lights, no way no how, plus I shift at the end while his still going, thats how that trans am kept up with me w/every shift I made and I think I am a pretty good shifter. Bottom line Kevin has the ideal setup. T4/t4 <---dunno the specs of his turbo since I dunno much about them, trust me I love that setup very much.
Old Sep 9, 2003 | 04:08 PM
IceY2K1's Avatar
Especially, considering he was NOT tuned and running on bad plugs.
BB turbos RULE!
Per Kevin:
Turbonetics T4/T04E turbo
Ceramic ball-bearing center section, wet housing (closing off the water passage for now)
Super series compressor wheel
Big shaft<~~~~
Polished compressor housing
Turbine side: On center, .81 A/R, "P" trim
Compressor side: "60" trim, 2.290" inducer, 2.950" major, 3" inlet
Old Sep 9, 2003 | 04:48 PM
IceY2K1's Avatar
Kev = Top two curves
You = Bottom two curves
I'm not sure I'm seeing what you're saying. Kevs puts down more HP until 6400rpm(redline) and more TQ until 6250rpm.
However, you would OWN Kev from 6500-7200 IF the SC can spin that fast.
Got JWT ECU?
Old Sep 9, 2003 | 05:04 PM
IceY2K1's Avatar
Just for kicks...Mardi vs. Kev
Old Sep 9, 2003 | 05:12 PM
JAY25's Avatar
Got JWT ECU?
you dont understand, I wont, it wont happen trust me on this one, not a chance, theres no way you can recover from 4plus car lengths thats just too much distance to catch up, plus you just said what I missed so with the HP he makes impossible, it all adds up now
Old Sep 9, 2003 | 05:17 PM
JAY25's Avatar
on that dyno plot Keving still would pull on Matt right away, remember is not the regular stuff here is that BB turbo. I seen one in action already, now can he close the gap I dont know, I lined up with him at the track when he had the 3.125 and he would pull away from me very fast, interesting to see these figures in paper.
Old Sep 9, 2003 | 05:24 PM
IceY2K1's Avatar
Mardi HP: 0-4200, 4750-redline
Kev HP: 4200-4750
Mardi TQ: 0-4100, 5100+
Kev TQ: 4100-5100
It's AMAZING how similar they are to 5000rpm, but 5000+ Bye-bye Keving.
Old Sep 9, 2003 | 05:33 PM
IceY2K1's Avatar
I'm betting with the new 3" exhaust things would change in Kevs' favor. He has to be choking that turbo by 5000rpm.
Old Sep 9, 2003 | 05:35 PM
Synki's Avatar
Geez, look at that A/F ratio.
Smoothen out that dip.
Old Sep 9, 2003 | 07:30 PM
Bags's Avatar
See I just find it when comparing dyno's you want to keep it as perfect as possible.
The DYNO charts ROCK!!!! BTW
But comparing 2 different cars on 2 different dyno's in 2 different regions just puts to many variables in there for me.
I understand why you did it, and I may play with ALL of them and try and make a cool chart in .pdf like you
Old Sep 10, 2003 | 04:23 AM
JAY25's Avatar
he loves that greddy like I doD:, yeah that solves the issue right there, the 2.5 exhaust, at 3 inch exhaust hes out there all the way to redline, is like you running breathing out of a straw, I try to explain that to a .org member last night talking about his exhaust is too loud. He can go and quiet it down but when that manifold exhaust gets too hot he will know why.
Old Sep 10, 2003 | 08:35 AM
Y2KevSE's Avatar
Matt had a 3" on, which really helped him. To give you an idea of how a larger exhaust helps, he made 337 hp and 285 torque without the 3" exhaust. I don't remember what he did between the two dyno sessions.
Sorry. The car was going to be tuned, but 2 of my plugs messed up on the dyno.
Old Sep 10, 2003 | 09:09 AM
Ramius83
Kev are you going to a custom 3 inch exhaust? or are you going to try to get one from warpspeed?
I personally love my Greddy SP, to me is not that loud compared to other exhausts I seen like the Stillen which is very loud. The custom 3 inch that Ramius has is pretty loud, bagss exhaust is not loud I can live with that. I was planning on contacting Greddy and see if they are willing to make me a 3inch exhaust, dunno if they would do that but hey nothing hurts to try
Jaime, the 3 inch exhaust does not affect the loudness of the car, it is the muffler that determines this. You can get the full 3 inch mandrel bent exhaust done at Grand Muffler (no welds all the way to the top of the axle) with your muffler for $275.00, just use a quieter/better muffler.
Old Sep 10, 2003 | 09:22 AM
IceY2K1's Avatar
He already went custom.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
