SC belt reccomendations and size, also oil
Old Oct 3, 2003 | 09:38 AM
Street Reeper's Avatar
Handsome
I did a search (and asked some other members) and only really found what I would need for a V2. I am going to be running a V1 with a 3.33 pulley and was wondering what would be a good strong reliable belt to use, what size, and where to get it.
Also, should I increase the weight of my oil when moving to SC? Right now I am using 5w-30 for winter, should I go ahead and move to 10W-30 or even 15w-40 (maybe in the summer?)
Thanks in advance
Old Oct 3, 2003 | 09:51 AM
[maxi-overdose]'s Avatar
belt - gates belt. I dunno the size that u need to use since you have a v1.
oil - I stay with 5w30 and the oil report seems fine. I switch to synthetic after the SC install.
Old Oct 3, 2003 | 01:44 PM
JAY25's Avatar
I agree with him stay with 5w30 for winter, if it gets p!ss hot where you live then consider going up to 10w.
Belt you can go with a gator back belt from Goodyear you can pick that up from autozone but dunno the size
Old Oct 4, 2003 | 06:31 AM
Handsome
Bump for the size of the belt, who could I PM about this. Is it a 6 rib 69.5?
Old Oct 4, 2003 | 01:33 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Jeremy,
I am running the 69.5, Dayco Poly Cog belt. As far as I know, the same size belt can be used for the 3.33 - 3.125.
Also I run 10W-30 regular oil, and always have been. Castrol Syntec. 85k on the engine, 60k on the blower, and all seems perfectly well. I have no plans to switch to synthetic.
Old Oct 4, 2003 | 02:09 PM
Handsome
Originally Posted by Craig Mack
Jeremy,
Thanks Craig, I'll PM you after I get the SC to let you know I am sending the money order for the pulley. Is anyone here running a 69.5 belt with a 3.33 pulley on a V1, just for clarification?
Sexima ran Mobil 1 through the blower and says that the bearings are perfect, I switched to synthetic last week (so that I could have one oil change while on synthetic before I install the SC) to keep the blower happy and according to the oil analysis here. The VQ is obviously very well ballanced and has very nice piston rings, I have no doubt that conventional oil would be fine. I just want to give my engine the best, and the blower what it is used to. Considering the increased temps with the SC just to be on the safe side I will probably run 10W-30.
Thanks for the reply
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
