Help! Little Plastic T (Pic Inside)
Old Oct 19, 2003 | 01:54 PM
MaximaRider's Avatar
I have this little 3 way plastic T that comes off the upper portion of the Vortech FMU and i need to get a 4 or 5 way one, does anyone know where i could find these? I went to homedepot but they have nothing that small?
Old Oct 19, 2003 | 01:58 PM
Here's another pic:
Old Oct 19, 2003 | 02:21 PM
thanks maxin i'll check them when i get a chance, there don't seem to be many around my school.
Old Oct 19, 2003 | 08:32 PM
JAY25's Avatar
the 4 or five way T gets connected to this to the fuel pressure regulator, from there you run a hose to the one end of the FMU. The other end of that FMU goes to your boost gauge.
the fuel pressure regulater is the round thing in the top center of the picture next to the nut. the rest of the outlets to the Vacuum to you can buy little rubber caps to cover them up. get a 5 way tee. You can get the vacuum T from autozone or pepboys. They come in Pink packages. Take the FMU with you and tell them I need a vacuum five way tee and they will point you to where they are at.
Look at the picture it has a black three way T fitting is plastic. You see it. Well hook it just like that and hook the BOV to it as well. You will have one extra hole left.
Old Oct 19, 2003 | 09:46 PM
Thanks for the pic, i have yet to look at that part of the car yet though, as for the 5 way tee, i know you suggested it because if i ever get a variable intake but alas i am pretty sure i will never get one. I see which hose goes to the FMU and th FPR but what is the hose with the numbers written on it going to? Also once again why do i need a 4 way tee? is there no boost line on that one?(for the boost gauge, mine came with a little plastic hose(kinda like a long straw) that i ran through the firewall. Sorry if i've been redundant i just want this to be 100% flawless because i don't think the stillen directions are going to help me very much considering most of the kit is modified and already put together.
Old Oct 19, 2003 | 09:53 PM
2 Items i don't need that you gave me Jaime:
-ancake Air Filter and T-Rex Pump
A couple more ?'s to save me some time
The new belt you gave me..that is for the 3.6 pulley correct?
The belt thats on the blower, that is for the 3.25 pulley correct? I am puzzled by the belt on my blower?
Old Oct 19, 2003 | 09:57 PM
nevermind i understand how the belt works thats on the blower, i was just playing with it upside down, stupid me...anyways, if you could give me detailed pics or descriptions of which hose goes where on the FMU i would greatly appreciate it, i don't have to buy any longer hoses correct? Also did you want my power steering lines?
Old Oct 19, 2003 | 10:27 PM
Trance Artur's Avatar
Home Depot
Old Oct 19, 2003 | 10:38 PM
ereet's Avatar
Hey Jay, is the hose with the yellow stripe (under the hose marked 3/16") the stock FPR vacuum hose? I think I'm still missing that one. I asked about it earlier but I figured the correct one was taken care of. Seeing the picture makes me wonder again.
Old Oct 20, 2003 | 06:24 AM
JAY25's Avatar
Arnaud no I dont need your power steering lines. The picture I posted is not of my car I believe thats a 99Maxima. Belongs to cranman. You wanted a fast answer so sorry about that. To better explain the picture, thats a three way vacuum t. The hose with the numbers is connected to a vacuum canister that opens the MEVI. Get the 5 way Tee anyways. and just buy the little caps, they are only like $2.00. Ereet sorry for not answering your question. Ill go and check and see if I have that hose connected in my car.
Old Oct 20, 2003 | 06:30 AM
JAY25's Avatar
Listen do not stress this install. I know how you feel somewhat nervous about the install. I gave you brand HP fuel hoses your fine with those. The FMU I will send you some pics of where they go exactly. Bottom fuel rail. Ill send you some pics. And if worse comes shove you have my home number or Ill call you after 9PM.
Jaime
Old Oct 20, 2003 | 06:56 AM
Stephen Max's Avatar
I believe that is the coolant line that goes to the throttle body. It would be on my 95, anyway.
Old Oct 20, 2003 | 02:10 PM
AHHHHHH every Autozone i goto only carry's 3 way (max) tee's wtf!!!
Old Oct 20, 2003 | 02:43 PM
JAY25's Avatar
You try pepboys and NAPA they carry them.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
NmexMAX
May 23, 2016 07:38 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
