Things not well in baggy land
Old Oct 25, 2003 | 01:03 PM
  #41
Jeff92se's Avatar
I'm needing a caw
Latin, what happened to the Vortech FMU?? The one with the discs correct? What are you going to use for FM now? Cartech?
Old Oct 25, 2003 | 02:14 PM
  #42
LatinMax's Avatar
Cartech it is. I posted here not too long ago to see what FMU the people that blew there motors had and all but 1 was the Vortech FMU. So it is gone!
Hey Dixit can you post the pics I sent you of my engine a while back, Thanks bro.
Old Oct 25, 2003 | 02:20 PM
  #43
BigDogJonx's Avatar
http://bigdogjonx.net/fullpics/misc/...yl%202-4-6.JPG
http://bigdogjonx.net/fullpics/misc/...0cyl%202-4.JPG
http://bigdogjonx.net/fullpics/misc/...cyl%20head.JPG
Those are the three pics of Gabe's engine. Very disturbing.
Dixit
Old Oct 25, 2003 | 02:25 PM
  #44
LatinMax's Avatar
Thanks...I almost forgot how ugly it was. It looks like a cat was bolted up in the cylinder.
Old Oct 25, 2003 | 02:57 PM
  #45
Ramius83
Well Bags, that just plain sucks. Especially since we just finished your 5-speed swap not too long ago. I think that this incident has been "building" on itself because of the amount of oil coming out of your crankcase filter/breather. Maybe that was just a forewarning of this event. Oh well, the worst is done now atleast. Again, if you need any help Bags, please let me know. You know that I will help you and who-ever out, so I have the knowledge to do mine if anything ever happens like this to me.
Old Oct 25, 2003 | 03:23 PM
  #46
|Bijan|'s Avatar
UCF Lexus
I'll be the one who makes runs to Home Depot, Auto Zone, and Pep Boys.....!!!!
Or....Taco Bell
Old Oct 25, 2003 | 03:51 PM
  #47
BigDogJonx's Avatar
Or....Taco Bell
That will be perfect.
Old Oct 25, 2003 | 05:32 PM
  #48
PRPmax's Avatar
Originally Posted by JAY25
leave him alone Nelson you have a heavy foot too
thats how the tranny went out
Nah my tranny went out cause of a shift into 3rd.
Old Oct 26, 2003 | 07:24 AM
  #49
JDM4LIFE's Avatar
bags, sorry about your story and situation. i had to replace my head gaskets last winter, and believe me... you want to take the engine out. it without a doubt is more work trying to get the heads off with the engine in the car (especially in ball-freezing weather without enough lighting, but that's besides the point...). if you have questions while taking the heads off, feel free to drop me questions. good luck!
Old Oct 26, 2003 | 08:50 AM
  #50
Bags's Avatar
VG Ridah's Biatch Hoe
Yeah I have thought about that as well.. your most likely correct.
And I am doing a little more checking but it seems it may be worth the extra couple hundred dollars to get another engine and swap it.
Rather than pull this motor tear it apart and try and fix it.
Plus I would then have a spare motor to start working on for my target WHP
Old Oct 26, 2003 | 08:52 AM
  #51
Bags's Avatar
Originally Posted by ejj
Bags, you could drop the oil pan(s) with the engine in the car. If you have rod failure or bearing failure, you would be able to see it that way. Removing the heads really does require the motor to be out of the car.
Sorry about the bad news.
But, on the bright side, motor swaps are fun!!
I may be PM'ing you with questions, but one big one on my mind is...
Did you leave the tranny connected to the motor when you pulled it?
Or did you leave it in the car?
I am thinking you have to pull it out as one unit. That's how the FSM shows it
Also, how HIGH up was your car? Ballpark guess is cool.
Old Oct 26, 2003 | 08:53 AM
  #52
Bags's Avatar
Thanks I just may do that
  #53
on_alert's Avatar
Perfect time to put in pistons and rods with an engine... see my other thread...
Old Oct 26, 2003 | 08:56 AM
  #54
Bags's Avatar
Originally Posted by LatinMax
OK Do you want the bad news or the godd news?
I know what is wrong......Trust me, I know (from experience)
You have denotated at WOT. and you will be putting in either a new engine or rebuilding the whole thing. The clanging sound is not the rod it is chunks out of the edges of your pistons.
Pull your plugs and you will find that the contacts are touching.
If you had a broken rod the motor would stop spinning completely.
The oil that is coming out of the breather tub is from the oil being pushed past the head into the valve cover from the boost.
That is exactly what my car looked like after my WOT run.
I have a question. Are you running a Vortech FMU?
And do you have the J&S setup?
Yeah vortech and NO on the J&S.
It's possible your correct. I was using a 6:1 disk @ 8 PSI.
However, my motor has been doing some things lately that leads me to thik this was just waiting to happen.
Old Oct 26, 2003 | 08:59 AM
  #55
Redmax's Avatar
Redlinemax Owner
You know , the J&S is looking better and better everyday
Old Oct 26, 2003 | 09:20 AM
  #56
Craig Mack's Avatar
All YOUR grammer belong to me
Bags,
How many miles did you have on your motor? Maybe it was already worn from the high mileage and just couldn't handle all that extra forced air...
  #57
Bags's Avatar
Unless your willing to put my on a payment plan, I can't step up to that yet.
But I am planing on doing something like that
Redmax, if your going over 8 PSI, it's my NEW suggestion
Old Oct 26, 2003 | 11:10 AM
  #58
JAIMECBR900's Avatar
As I told you last night, I'm ready to help when you are. You know I aint scared to jump in there and get dirty.
Let me know what you need and when you need it.
Old Oct 26, 2003 | 01:32 PM
  #59
plurco's Avatar
Originally Posted by bags533
Well last night my car starts smoking and making a bad knocking noise...
I get of the road and pak look under the hood, about a QT of oil shot out of the crankcase filter.
There is smoke coming form near the dipstick and out of the exhaust. It is idiling very rough.
I rev it and it sounds as if 2 hammers are smaking each other.
Not at idle and not in rhythm.
So it is not looking good for the home team..
A compression test will be done very soon and then towed somewhere.
Man I hope I don't need a new motor.
well Man I remember you saying a while back that you had oil in your VI chamber. I also had this problem and it was due to low pressure in one cylender. I was also using about a quart of oil every 700-1000 miles which I also think I remember you saying also. If you had the same problem I had boost would greatly increase the chances of a blown engine. Luckily these VQ's are a dime a dozen. I just bought one with 18K miles for $425 shipped.
Old Oct 26, 2003 | 01:46 PM
  #60
Bags's Avatar
Originally Posted by Craig Mack
Bags,
131,000 + miles
jaime- I know and I Thank you for it
Old Oct 26, 2003 | 03:46 PM
  #61
|Bijan|'s Avatar
UCF Lexus
131,000 + miles
VQs can go!
Old Oct 26, 2003 | 07:04 PM
  #62
nupe500's Avatar
Jedi Knight
VQs can go!
Yes they can,
Bags, With the 5 speed tranny it is easy to pull both the motor and the tranny thru the top, you just have to tilt the engine a bit to get it out...easier than lifting the car. That is what I did with my swap. it was really easy...only thing is you should make sure you get a year specific engine or at least stay in your year range. I had some sensor issues in putting a 97 engine in a 95, so I ended up swapping wiring harness and everything else...good luck.
Old Oct 26, 2003 | 08:19 PM
  #63
Redmax's Avatar
Redlinemax Owner
Bags my goal is 14lbs
Old Oct 26, 2003 | 09:14 PM
  #64
Bags's Avatar
Originally Posted by nupe500
Yes they can,
HMMM.. I was going under rather than over.
I was able to get the front end 2+ feet off the ground when I pulled the tranny, I was shooting for 3 feet this time.
And on the motor, I was thinking that tonight, I am looking at a 96 ( I think ) but was worried about sensors and such.
The only one is the rear 02 sensor, that I know about.
We will see... I have a 96 ECU though..lol so it may work out. And when I get the JWT ecu it will really work out.
Thanks for the info..
any more just post away.. the plan is to start next sunday
Old Oct 26, 2003 | 09:16 PM
  #65
Bags's Avatar
Mine as well....
actually 400+ WHP/TQ.. I am thinking 9:1 Compression and 14 PSI, 550 CC Injectors, and JWT ecu Should get me in the ball park.
Old Oct 27, 2003 | 04:17 AM
  #66
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Oct 27, 2003 | 04:23 AM
  #67
ejj's Avatar
ejj
My car was only about 18" up. I took the tranny out as if I were replacing the clutch (out the bottom of course), and then pulled the engine out through the top.
Going down with it is easy, but I couldn't get the car high enough to do so. Working with the tranny and engine seperate weren't that big a deal.
If you've got questions feel free to let me know. Remember, its fun!
Old Oct 27, 2003 | 07:04 AM
  #68
Quicksilver's Avatar
OT n00bs FTMFCSL
Dude, that sucks goat *****...
Let me know if you need any hands or eyes...I'll donate.
Old Oct 27, 2003 | 10:34 AM
  #69
Stephen Max's Avatar
I redlined 2nd @ WOT, followed by redlining 3rd @ WOT, followed by redlining 4th @ WOT, followed by seeing how close to redline I could get in 5th @ WOT.
I made it to about 5400 RPM
That's when I heard the noise.
Sorry to hear about this, Kirk.
Do you know what your EGT got to? That's a lot of time to be spending at 9 psi and WOT.
Old Oct 27, 2003 | 10:54 AM
  #70
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Hmmmn....Can anyone explain WHY all THREE of these cylinders "broke" on the same side? I think we should do some digging to see what could have caused that and why.
Old Oct 27, 2003 | 11:03 AM
  #71
The only thing off the top of my head that all 3 cylinders would share that would cause problems if it went out is....injector rail. Maybe a total clog of rear section of the injector rail???? That sounds way out there, but that's the only thing that all 3 cyls "share".
Old Oct 27, 2003 | 11:20 AM
  #72
OT n00bs FTMFCSL
Maybe it was crank whip, or perhaps the crank twisting slightly...
Those are both kinda far-fetched, too...
Old Oct 27, 2003 | 11:32 AM
  #73
They also share the intake and exhaust valve locations. The pistons failed near the intake valves. Does it get hotter there? I would think the opposite would be true with fresh air coming in that side.
Old Oct 27, 2003 | 11:39 AM
  #74
Yes, but if you float a valve or drop one, it is highly unlikely to take out the other two cyls. It normally would tear up the cyl connected to, but not the rest. Unless you blow a timing chain.
BTW, what do you mean near the intake valves? Each piston has a set of intake and exh valves directly above it.
Old Oct 27, 2003 | 11:42 AM
  #75
Judging by the extreme pitting marks on top of the piston, I would guess that another possibility would be some serious detonation issues.
Notice that the pistons all have severe pit marks from something breaking apart in the top part of the cylinder.
It is kinda weird how the cylinders so vastly differ in color. What's that a sign of?
Old Oct 27, 2003 | 12:06 PM
  #76
What I meant was that the piston damage for all three occurred at the side of the piston where the intake valves are located. Maybe that's just a coincidence. I didn't catch the significance that all three were on the same bank, which lends credence to a fuel distribution problem for that bank.
Old Oct 27, 2003 | 12:48 PM
  #77
BigDogJonx's Avatar
It was definetely detonation, but why it happen on just the whole front bank, I have yet to figure that out. The pieces of the Piston head were stick in there and thats why you see all those marks like Gabe explained.
Dixit
Old Oct 27, 2003 | 01:01 PM
  #78
IceY2K1's Avatar
"Detonation induced pre-ignition"
http://www.streetrodstuff.com/Articl...asics_VIII.php
I think detonation from too lean a mixture led to pre-ignition and blowing through/past the rings. However, as StephenMax suggested, I too think that would have occured near the exhaust port side NOT the intake.
Those pits are from pieces of metal beating the top of the piston NOT detonation. Detonation has more of a sand-blasted look IIRC.
Old Oct 27, 2003 | 01:12 PM
  #79
IceY2K1's Avatar
Gabriel and Bags...I need pictures of the plugs, especially the insulators.
BTW...what heat range plugs were you running?
Old Oct 27, 2003 | 01:23 PM
  #80
IceY2K1's Avatar
Maybe not pre-ignition after all:
"The detonation, the mechanical pounding, actually mechanically erodes or fatigues material out of the piston. You can typically expect to see that sanded look in the part of the chamber most distant from the spark plug, because if you think about it, you would ignite the flame front at the plug, it would travel across the chamber before it got to the farthest reaches of the chamber where the end gas spontaneously combusted. That's where you will see the effects of the detonation; you might see it at the hottest part of the chamber in some engines, possibly by the exhaust valves. In that case the end gas was heated to detonation by the residual heat in the valve."
That DEFINITELY happened on the MIDDLE cylinder. Wouldn't TOO SMALL an exhaust or heat backing up from a restrictive turbo cause that?
Why all three would fail in the SAME place?
"Many times you will see a piston that is scuffed at the "four corners". If you look at the bottom side of a piston you see the piston pin boss. If you look across each pin boss it's solid aluminum with no flexibility. It expands directly into the cylinder wall. However, the skirt of a piston is relatively flexible. If it gets hot, it can deflect. The crown of the piston is actually slightly smaller in diameter on purpose so it doesn't contact the cylinder walls. So if the piston soaks up a lot of heat, because of detonation for instance, the piston expands and drives the piston structure into the cylinder wall causing it to scuff in four places directly across each boss. It's another dead give-a-way sign of detonation. Many times detonation damage is just limited to this."
