is 262hp and 239tq normal for 9psi???
sorry for not posting enough information....
i drive a 5 speed and i am supercharged......
the numbers seem kinda low to me.....
but my engine light is on and i have a problem with the vacuum.... (swirl control valve)
wonder if that affects the horsepower
yeah i just dynoed with stock ecu, stock injects, and seeing ~6-7psi (dont know why)...maybe someone can help me out with why i am not seeing 10....
but i got 286hp 262tq and i am HOG rich (10:1 after 2.5k rpm)
so i would definately say your numbers are low. what were the conditions on the run? was the car cooled down fully? outside temp? is that your only code coming up?
--Paul
--Paul
Originally Posted by JAY25
what type of boost gauge do you have? If you have the cheap autometer ensure the line is not pinched since its made out plastic..
i had 270 b4 when i was lean at 14, but that is cuz there is supposed to be more power when lean....
and i have engine loghts on
dont know what the codes mean
1130
0140
0505
--Paul
--Paul
I was seeing exactly 7.5PSI when I should have been seeing 10.
IanS
P1130 - Swirl Control Valve Control Solenoid Valve
P0140 - BANK 1, REAR 02-sensor HIGH VOLTAGE
P0505 - Idle Air Control Valve(IACV) - Auxiliary Air Control(AAC) Valve
1130
0140
0505
1130
0140
0505
RWCreative
Sep 21, 2015 11:01 AM
