Quote:
yes. Originally Posted by spanishrice
Have you ever blown an engine?
but never when my car is set at something reliable, such as my 476 dyno. It's when I get crazy that trouble comes (18psi, excessive n2o, etc)
julio: i'll have to get back to you a little later, all my stuff is in the car right now. the turbo is nothing giant, but does very well
Oh....................Originally Posted by hlh0501
yes. but never when my car is set at something reliable, such as my 476 dyno. It's when I get crazy that trouble comes (18psi, excessive n2o, etc)
[/QUOTE]
I was also wondering if you have a 270 or 360 degree thrust bearing.
I was only wondering about you a/r sizes cause you say that you get boost pretty early, which probably means you have a small a/r on at least one of the two sides, if not both. The info is def appreciated!
[/QUOTE]I was also wondering if you have a 270 or 360 degree thrust bearing.
Since he runs a hybrid turbo, the AR really doesn't need to be that low.
I was only wondering about you a/r sizes cause you say that you get boost pretty early, which probably means you have a small a/r on at least one of the two sides, if not both. The info is def appreciated![/QUOTE]
Quote:
I was also wondering if you have a 270 or 360 degree thrust bearing.Originally Posted by Julio
