Tomei Z32 plug/pigtail?
Old Feb 24, 2004 | 03:07 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Would this be worth $20-$30 or is it easy enough just to splice the Z32 in place of the A32 connector? Or are they the same?
Old Feb 24, 2004 | 03:20 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
splicing the one on Max ODs 3rd gen took 5 minutes...that beats $30 IMO chop off Max plug, wire in Z32 plug. I think the plugs are different, if I can remember one had an extra ridge on the plug or something, so they can't fit in the same slot I think, but no the wiring isn't the same at all
Old Feb 24, 2004 | 07:06 PM
Confused's Avatar
Permanent Maxima.org Resident
it all depends how much you can source a connector for.. z harnesses are more valuable than 3rd gens but should be the same maf connector
Old Feb 24, 2004 | 07:35 PM
Ramius83
However, I thought that the Z-mafs have a 5-wire harness on them??? Please correct me if I am wrong.
Old Feb 24, 2004 | 07:54 PM
Stephen Max's Avatar
They have a four wire harness and a six pin connector (two pins aren't used). There are two ground wires, one 5V source and the maf sensor output wire. I don't know why it uses two ground wires, but one is connected to the ground wire in the harness (maybe it goes to the ecu), and the other goes to some other convenient grounding location of your choice.
I bought the Tomei plug and used it for my Z32 maf. It's convenient if you can't find one in a junkyard.
Old Feb 24, 2004 | 09:00 PM
DA-MAX's Avatar
I'm pretty sure the connectors were no where near the same
Old Feb 25, 2004 | 08:58 AM
IceY2K1's Avatar
Thanks......
Old Feb 25, 2004 | 02:21 PM
maxlinegtr's Avatar
can one of u guys make a map out of where the wires goes?
Old Feb 25, 2004 | 02:29 PM
I'm pretty sure I've got a jpeg of that at work. I'm at home right now, so hold on till tomorrow ...
Old Feb 25, 2004 | 02:50 PM
maxlinegtr's Avatar
I don't know how far maximas would go without u guys. I thank u.
Old Feb 25, 2004 | 02:52 PM
DA-MAX's Avatar
theres a diagram on JWTs site...not Maxima specific but you can get an idea from it
Old Feb 26, 2004 | 04:47 AM
Okay, here's what I got.
This came from: http://www.sr20development.com/LIBRARY/LIBRARY.html
Old Feb 26, 2004 | 07:23 AM
delio's Avatar
the third gen maf plug works 100% no problems there.
The Tomei one does make life simple though.
Old Feb 26, 2004 | 07:27 AM
DA-MAX's Avatar
really...then I ****ing wired his car up for nothing...WTF? he was so sure we needed the Z32 plug, he chopped the 3rd gen one off, so I went ahead and searched high and low for a Z32 plug and wired it up...arrrrrgh time for me to go smack somebody up! and you're 100% sure the wiring positions are 100% the same?? then that means I can sell this other plug lying around...if I can find it at the shop
Old Feb 26, 2004 | 07:59 AM
delio's Avatar
my car runs and drives... I am using Jeff92se's 3rd gen plug...
As far as the 3rd gens, I don't know if the wires themselves are the same but the pins are in the right spots, so you could clip it into the maf, and maybe have to modify a couple of wires in the harness
but for dead sure, the plug works.... It's even in the JWT PDF I have...
And to boot it says...
ADAPTING A 90+ 300ZX MAF SENSOR 22680-30P00
INTO OTHER NISSAN CONTROL SYSTEMS
NOTE: A JWT ECU PROGRAMMED FOR THIS CHANGE MUST BE USED.
89-94 MAXIMA MAF IS THE SAME PIN FOR PIN, BUT IS NOT THE SAME CALABRATION AND
CANNOT BE SUBSTITUTED FOR THE 300ZX MAF.
So I would take that to mean... that the pinout is identical, but you need to actually swap the MAF.
Old Feb 26, 2004 | 08:11 AM
DA-MAX's Avatar
interesting, makes sense to me
Matt93SE
May 24, 2019 02:58 PM
BkGreen97
Apr 2, 2016 05:47 AM
fulloboost
Sep 12, 2015 08:03 AM
Y2KevSE
Jan 20, 2002 01:54 AM
CalsonicSE
Oct 10, 2001 11:12 AM
