Aquamist before or after the SC??
Where do you guys that run the Aquamist put the jet? Before the SC or after?
I thought after would be good, but will all the boose blow the jet out or loose boose thru the Aquamist water line?
Where has it been done or where do you think it should be done?
Thanks in advance,
Gabriel
Thanks in advance,
Gabriel
I *THINK* Aquamist recommends 18" or so before the throttle-body. Double check though.
I wouldn't run it through the SC, so I'd put it after your BOV and before the TB.
I think Kev had some pictures of his, you might see if you can see his nossle placement.
My BOV sits too close to the throttle body to add the nossle after it.
Originally Posted by subs1000w
you want it closest to the throttle body so that would be after the sc
close to the TB, you dont want that water touching the MAF or the AIT. Water and electrical components dont mix too well.
jhans114
Apr 26, 2002 03:45 PM
Y2KevSE
47
Feb 26, 2002 08:36 PM
