Aquamist Power Gain
Old Mar 5, 2004 | 03:29 PM
iansw's Avatar
Aquamist Power Gain
Does anyone have any solid proof of power gain with Aquamist?
I've never seen any - so I'm asking.
Old Mar 5, 2004 | 08:09 PM
stephenlc's Avatar
I think not so much a power gain for the actual aquamist, I believe it lets you boost a couple more pounds lowering the risk of detonation. So you make more power from the extra boost.
Old Mar 5, 2004 | 08:40 PM
iansw's Avatar
From what I've heard, the lowering of the air temp causes O2 to be more condensed, thereby causing more power.
Old Mar 5, 2004 | 09:36 PM
nismology's Avatar
Yes but at the same time it also displaces the oxygen in the combustion chamber.
The primary objective of aquamist as i understand it is to absorb the heat from the combustion chamber to allow higher cylinder pressures (more boost) without detonation. An added benefit is cooling the intake charge.
Old Mar 5, 2004 | 09:37 PM
iansw's Avatar
Understood.
I was asking about the added benifit specifically, that's all.
Old Mar 5, 2004 | 09:47 PM
nismology's Avatar
Oops... Sorry...
Old Mar 6, 2004 | 08:59 AM
MardiGrasMax's Avatar
You can also keep the boost level the same and advace the timing more, this will pickup some power too.
Old Mar 6, 2004 | 10:47 AM
subs1000w's Avatar
i read that it also rids the engine of carbon deposits and keeps it sqeaky clean
Old Mar 6, 2004 | 11:28 AM
Maximum Performance's Avatar
here is some info on aquamist on a turbo 1.6 nissan
http://www.nissanperformancemag.com/.../project200sx/
leatherneck
Sep 30, 2015 09:16 PM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
