A/F gauge ?
Old Apr 7, 2004 | 01:34 PM
KMax2988's Avatar
A/F gauge ?
Have a quick question on which wire to tap on the ECM for my Dynotune A/F gauge. Wondering if it would matter if I hooked it to pin 56 (rear o2) on my 96 Max rather then 50 or 51 (right or left front o2). The reason I ask is because hooking it to 56 would essentially read both banks as opposed to reading either bank 1 or 2 (if it matters in terms of reading which bank is lean or rich). Let me know what you guys think. Thanks
Old Apr 8, 2004 | 07:08 AM
meccanoble's Avatar
Sports Button FTW
bump for a friendly member
Old Apr 8, 2004 | 07:14 AM
Stephen Max's Avatar
The rear heated O2 sensor will not give you correct afr readings, since the catalytic converter uses some of the oxygen in the exhaust to do its thing. You will get false rich readings. The rear O2 sensor is only used for monitoring the cat.
By the way, don't expect to be able to do any sort of tuning with the oem narrow band O2 sensors. An EGT gauge is more useful in that regard.
Old Apr 8, 2004 | 09:39 AM
Synki's Avatar
Exactly. Either go EGT or get a true W/B 02 sensor. That is as accurate as you can get.
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
