N00b Question
Old Apr 17, 2004 | 06:04 PM
MaxSpeedSE's Avatar
N00b Question
Hey is it tru you can run a 75 wet shot of nitrous with a superC setup of 10 psi, if u upgrade your fuel, and make sure your motor is getting enough fuel with aftermarket injectors?
I was talking to somebody and this is what he told me... that set up seems wicked fast...but i donno, is it possible?
Old Apr 17, 2004 | 10:32 PM
JeffesonM's Avatar
living out of a maxima...
I believe with a wet kit the extra fuel is added through a jet at the same place the nitrous is. Assuming the stock injectors can handle a supercharger@10psi you should be okay. I don't know enough about the system to know where it gets the fuel, so I'm not sure if would effect fuel pressure to the injectors or not. I know Hal ran a smaller shot with his turbo@10psi and produced some great numbers.
Old Apr 18, 2004 | 03:21 PM
BigDogJonx's Avatar
You are not going to be able to sucessfully run 75wet shot on a 10psi SC without blowing something up. UJnless you run C16 race gas with the J&S, you can probably get by.
Dixit
Old Apr 18, 2004 | 04:57 PM
MaxSpeedSE's Avatar
I dont mean to put his name out there, but SeximaGTR ran this setup and told me he had no problems?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
