Power Enterprise 380cc/510cc injectors AND Walbro 255lph HP
Old Apr 23, 2004 | 11:44 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://www.gruppe-s.com/350z/zeng.htm
Fuel pump looks like a pretty good deal, since it comes with all the extras:
Doubt the extra capacity oil pan would fit.
Old Apr 23, 2004 | 12:47 PM
stephenlc's Avatar
Why are they switching to a timing belt?
Old Apr 23, 2004 | 12:49 PM
IceY2K1's Avatar
Good question~! Don't know.
Less noise? Less friction?
If I ever pull of the timing cover, I'm going to see if I can't swap to a 3rd gen VQ35 silent chain.
Old Apr 23, 2004 | 04:47 PM
stephenlc's Avatar
Maybe to tune cams? I am sure it is a lot easier than a chain.
That is not a bad price either. Are the 350z pulleys different than the maxima vq35 pullies?
Old Apr 23, 2004 | 07:44 PM
BigDogJonx's Avatar
Yea id like to know about the timing belt. Cause it definetely is a sprocket based system with the chain, cant just take the chain off and use a belt. Shiet.... there is baerly enough room for a belt not to mention that whole case sits in a pool of oil.
Something is wrong on that ad.
Dixit
Old Apr 24, 2004 | 06:31 AM
Confused's Avatar
Permanent Maxima.org Resident
isn't that the replacement pan for PE's TT setup?.... a little pricey but would be sweeter than tapping your own upper pan (if it fit)..
Old Apr 24, 2004 | 07:22 AM
stephenlc's Avatar
I rather save 500 dollars. Unless I was going to autocross all the time.
Old Apr 24, 2004 | 10:11 AM
IceY2K1's Avatar
Yep. I think oil cooler(s) would be cheaper/more effective cooling wise, but with the extra QUART or so of capacity, that would be interesting. I just doubt the pickup would be compatible/optimally located on a transverse mounted engine.
I'd also have to monitor before/after turbo install oil temps to know whether it's necessary or not, ESPECIALLY since I'd only choose water cooled CHRA turbos.
Old Apr 24, 2004 | 02:27 PM
Dreizehn's Avatar
What do you mean silent chain? The VQ30 has a roller chain if that is what you're referrring to...
Old Apr 25, 2004 | 08:53 PM
IceY2K1's Avatar
It has a better/quiter chain that hits the sprockets at less of an angle or something, so it's quiter the the VQ30s had.
I'll post more details tomorrow.
Old May 4, 2004 | 10:48 AM
stephenlc's Avatar
Dixit
http://z1auto.com/prodmore.asp?model...ine&prodid=697
That is the link on information about it. Plus ran into some new stuff nismo is making.
http://z1auto.com/submodel.asp?model=350z&cat=engine
Look at the NISMO VTC Pulley!
Old May 7, 2004 | 02:30 PM
Synki's Avatar
Its a pretty good deal. Gruppe-S is very rep. We have dealt with Max there numerous times.
Adam @ Z1 is also a great guy to deal with. Goes out of the wayt to help.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
