Good read on cams
Old May 26, 2004 | 12:50 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Good read on cams
I stumbled upon this while searching Google and happened to read through it. Glad I did, so I thought I'd share for the rest of the cam newbs like myself that don't know how in the hell companies like JWT come up with profiles for our engines.
http://www.realoldspower.com/tech/valve_timing.htm
What I got from it was that I need to do *A LOT* more homework before I ever consider such a dramatic mod.
Old May 26, 2004 | 01:38 PM
bighunt's Avatar
that's way over my head. i need an engine 101 lesson!!!
Old May 26, 2004 | 01:45 PM
IceY2K1's Avatar
Try this maybe?
http://auto.howstuffworks.com/engine.htm/printable
Old May 26, 2004 | 02:03 PM
bighunt's Avatar
thanks Ice. i've seen that and been reading through it. but i'm someone who needs to learn w/a hands-on approach. i need to get my hands dirty in the car to understand how stuff works.
Old May 26, 2004 | 02:46 PM
IceY2K1's Avatar
I agree...hands on is best. I try and get dirty as much as possible, but it's usually helping on someone elses car. Mine never break~!.
Old May 26, 2004 | 03:34 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Originally Posted by IceY2K1
Mine never break~!.
*cough* lack of boost *cough*
Old May 26, 2004 | 03:35 PM
Bags's Avatar
oh and great find.. and i agree, last thing I'll mess with is cams
Old May 26, 2004 | 04:06 PM
Mad-MAX_SE's Avatar
Still kickin'
wow there is more info in there than you can shake a stick at...cams i guess should be the last thing you get then. but if you change anything, it could be the cams affecting your performance...not your new turbo or s/c. great find Icey...i gotto read that few more times so that it sets in, lol.
Old May 27, 2004 | 07:42 AM
MAXimumHP's Avatar
Thanks for the link, there's some good reading there
Old May 27, 2004 | 09:02 AM
IceY2K1's Avatar
Anybody know what the JWT VQ30DE cams are designed for? High RPM NA? Turbo? SC? Are there different version available?
According to my "Maximum Boost" by Corky Bell, he says for turbos, you'd be hard pressed to find a better performing cam then the STOCK cam.
I'll expand why later, but it's primarily because of its short duration and not much overlap.
Old May 27, 2004 | 09:18 AM
maxlinegtr's Avatar
Can someone put this as a sticky or somthing. great enlightening info. Good Ish Icy
Old May 27, 2004 | 09:10 PM
IceY2K1's Avatar
Okay....."Maximum Boost" by Corky Bell.
Make no mistake in the fact that turbo performance cams are very different from atomospheric performance cams. The characteristics of long duration and high overlap for atmo cams are unwelcome in a turbo system. The street turbo, which is generally small, operates with the exhaust manifold pressure somewhat higher than intake boost pressure. This situation, when presented with long duration, high-overlap cams, creates a huge amount of reversion. Thus the "turbo cam" tends to become a low-duration, very limited overlap cam.
RULE: It is hard to find a turbo cam that works better than the stock item.
Is it necessary to change the cam?
No, decidedly not. Stock cams usually work excellently. For the absolute last word in a super-boost(15psi) performance turbo car, a change of cam will be necessary, but so will several other things. Leave the stock cam alone and you will generally be much happier.
Old May 27, 2004 | 09:14 PM
IceY2K1's Avatar
Got some more good stuff from Corky Bells' book on turbo pistons and head gaskets, I'll have to start a new thread.
Old May 28, 2004 | 08:04 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
You can go with larger lift cams, close to stock duration, and close to stock overlap without sacrificing power/mileage too much (with the same lobe angle...maybe one or two degrees difference). Too much valve overlap and the turbo will blow the fuel/air mixture right out of the combustion chamber without ever igniting it! That would obviously be a bad cam choice...
The easiest thing to learn on is a simple aircooled VW engine (believe it or not). Check out the "turbo cams" that are made for those particular engines, and you'll get an idea of what you can and can't do with a boosted engine. I tried 5 different cams in my prior turbo Bug before I found what I was looking for. Lucky for me they weren't that expensive! But changing four cams on one engine...Jesus! A mistake there could set you back for months (money wise)!
Old May 28, 2004 | 08:53 AM
IceY2K1's Avatar
Yes, I agree...you would benefit, however most likely NOT enough to justify the cost $1000+, the labor ~$350, and the lope/idle UNLESS you're going over 15psi, which *MOST* here don't.
I think Mardi is the only one and he's found that the trans can't tolerate that and I'm sure if he does for much more time, the internals need upgraded. Once you tear the engine appart for internals, head studs, new gasket, I'd worry about a better cam.
All this isn't necessary until you're planning 15+psi probably.
Old May 28, 2004 | 09:23 AM
IceY2K1's Avatar
Okay...JWTs website says 256-degree .415" gross lift.
Looking at my STOCK cam specs in the FSM, it appears:
Intake is 224-degrees
Exhaust is 232-degrees
Overlap is 6-degrees
Intake opens 3-degrees BEFORE TDC
Intake closes 41-degrees AFTER BDC
Exhaust opens 49-degrees BEFORE BDC
Exhaust closes 3-degrees AFTER TDC
Cam height:
Intake 43.940-44.130(1.7299-1.7374)
Exhaust 44.465-44.655(1.7506-1.7581)
What does '.415" gross lift' mean?
Old May 28, 2004 | 09:34 AM
IceY2K1's Avatar
Here's a picture incase it helps:
Old May 28, 2004 | 10:13 AM
Stephen Max's Avatar
I use to love working on bugs and the aircooled Vanagons. Only one cam, but you have to split the cases to get at it. But it only takes 45 minutes to pull the engine, and that's with a beer and cigarette break.
Old May 28, 2004 | 10:27 AM
Jeff92se's Avatar
I'm needing a caw
I've read that what's good for the goose in general is good for the gander. I would think a mild cam would be a good choice for a turbo also. But as with most performance cams, you loose what I'll call "dyanamic compression". If you have too much duration and overlap, you will also loose the exahust velocities that drive the turbo. So as with anything, you might gain hp up top but the turbo spool would probably suffer also.
Old May 28, 2004 | 10:36 AM
OT n00bs FTMFCSL
I wouldn't pay for labor, but then again I tend to do all motor work (except for certain things like decking, clearancing blocks, machining heads, and boring out cylinders) myself...cam swaps included.
Old May 28, 2004 | 10:54 AM
Nismo87SE's Avatar
Cams are an excellent mod, I think you VQ guys are SOL because the engine is DOHC. The cam install on a SR, VG, KA, GA is pretty easy. Also whoever said stock cams are usually best for boost is wrong. As long as there isn't alot of overlap a cam will make big power with boost.
Old May 28, 2004 | 11:00 AM
IceY2K1's Avatar
Just Corky Bell....
http://www.datsun.org/fairlady/CorkyBell.htm
Old May 28, 2004 | 11:11 AM
OT n00bs FTMFCSL
The man is definitely an idol of mine when it comes to vehicle performance...
I forgot he does Flyin' Miata turbo kits. I might build a 94-95 Miata turbo (stroker 2.0L)...
Old May 28, 2004 | 11:25 AM
IceY2K1's Avatar
You sure about that?
I thought Limit Engineerig or was it LLC Engineering in Lake Havasu, AZ did the Flyin' Miata kits?
I'll go double check.
Old May 28, 2004 | 11:33 AM
OT n00bs FTMFCSL
When you go thru the BEGi homepage and go to the Supercharger/Turbocharger kits, it goes straight to FM's turbo kits...
Old May 28, 2004 | 11:42 AM
IceY2K1's Avatar
Damn it...I deleted it, but it was last months "Garrett Gearhead" had an interview with the owner of IIRC Limit Engineering or it was the other shop in Lake Havasu, AZ and he said that was one of the kits he produced. Maybe they contract out the machine work to LE?
Old May 28, 2004 | 12:29 PM
JeffesonM's Avatar
living out of a maxima...
Very interesting reading... there sure is a lot to think about when designing cams.
That being said, I'm not sure why this would sway anyone's feelings on upgrading their cams one way or another... it's not like we were all planning to go out and design our own cams. The fact that it's a really complex component doesn't mean much for the end-consumer... it's JWT that has to do all the work. For us, it's still pretty much a question of where you want the power and if the $/hp ratio is worth it.
Old May 28, 2004 | 01:10 PM
IceY2K1's Avatar
Agree, but has anyone asked what type of setup JWTs cams are designed for? High RPM NA? SC? Turbo? If one of the FI cams, what RPM range are they optimized for?
I kind of wonder how you can only sell a "one fits all" cam.
Old May 28, 2004 | 01:22 PM
JeffesonM's Avatar
Probably the same way they have a "one fits all" ECU program
Old May 28, 2004 | 01:26 PM
IceY2K1's Avatar
I FORGOT the sarcastic smiliey.
Old Jun 6, 2004 | 01:18 PM
Mad-MAX_SE's Avatar
Still kickin'
i just read in the july issue of Modified Mag that cams only spin half the revs of the crank. so when you're at like 7k, the cams are going 3.5k. i dunno why i never realized that before. I recomend getting this issue...they have a great article on cam selection with pictures and everything.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 12, 2016 04:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
95naSTA
Aug 16, 2015 05:03 PM
95naSTA
Aug 16, 2015 05:02 PM
