What turbo sizes are you running?
Old Jun 3, 2004 | 07:00 PM
carnal_c30's Avatar
Former Sponsor
just have a few questions on what sizes and the specs of the turboes every one is using
I know most everyone is using a T3/T4 or a T04e... but what are the specs on them?
The PFI T04e uses a .81 A/R which seems to me a bit high... what are the A/Rs of the other kits and turbos everyone is using?
anyone have any complaints about a Garrett T04e 0.70 A/R compressor housing 0.60 A/R exhaust housing??
I would really appreciate ideas and opinions...
Old Jun 4, 2004 | 01:11 AM
mingo's Avatar
we flow enough exhaust gas to run just a to4e.. forget the t3/t4 setup unless u plan to do more twisties and what not.
Old Jun 4, 2004 | 05:21 AM
stephenlc's Avatar
Our exhuast manifolds are very inefficient. I have seen 1.6 liter B series fully spool a t3/t4 at 3000 rpm.
Old Jun 4, 2004 | 06:41 AM
JAY25's Avatar
I have a T4/TO4E. AR81. Yes a 60 or a 70 AR would be better. 81 is good for top end runs. I would not get a .81 for a non ballbearing turbo. Id get a .58, .6?, or even a .71.
I have stock manifold on my car. Put out 353HP 318lbs of torque, so I am confused as where is the inefficiency? Ramius put out 400HP/360lbs of tq with a spike to 11PSI. He has stock manifolds.
Old Jun 4, 2004 | 08:06 AM
carnal_c30's Avatar
Former Sponsor
One of the turbos I peeked at was a Garrett T3/T04e super 60 with a 0.63 A/R turbine (exhaust) housing. 0.50 A/R compressor housing- pretty decent size... maybe a bit small
another T3/T04e combo is an0.70 A/R compressor housing and i choose exhaust housings from 0.48 A/R, 0.63 A/R, and 0.48 A/R Dodge/Chrysler T3 turbine housings. it has a 57 Trim Garrett compressor wheel
they're ok, but yea Daniel my car just goes down the freeway really fast haha I have my 240sx for the twisties
I cant find too many sites that have a good selection of turbos at good prices, especially T04 turbos that dont have huge A/Rs for domestics
Old Jun 4, 2004 | 08:17 AM
Bags's Avatar
VG Ridah's Biatch Hoe
www.cheapturbos.com
Old Jun 4, 2004 | 08:21 AM
Bags's Avatar
oh an T3/T4 .70 compressor .63 turbine
Old Jun 4, 2004 | 11:04 AM
Royal_T's Avatar
I just orderd my turbo from cheapturbo.com. It was a T04E with a .70a/r, they told me that the .81a/r was out dated and that they do not have that a/r anymore. But the .70a/r should be good for top end as well.
Old Jun 4, 2004 | 02:09 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Woah...don't forget the I4s have that turbo practically sitting on the exhaust ports compared to the Max's 10-mile reverse y-pipe, so that adds lag. Not to mention I4s can easily run divided turbine housings to offset one-to-two size larger A/Rs.
As far as I remember, a PFI T3/T4 was hitting ~6psi by 2800rpm even with that super long reverse y.
Old Jun 4, 2004 | 07:53 PM
Ramius83
As Jay has mentioned, we are both running the same turbos on nearly the same turbo kit.
I have a Turbonetics T4/TO4E Ball Bearing Turbo. It has a .63 on the compressor and a .81 on the turbine. I purposely chose the larger exhaust side so that I could atleast start moving before I hit full boost and lost traction. But I still loose traction regardless if I am in 1st, 2nd, or even 3rd. I start boosting by 2400ish and I have max boost regardless of psi setting at around 3500ish.
When I dynoed untuned, I had it dialed in at 10.3 psi and I had an 11 psi spike that was held constant throughout the run. At that 11 psi line, I have a little over 400whp, and around 368 TQ. (Torque levels are low because of no moving air on the dyno to cool down the IC).
I would rather have the top-end power with a larger turbine, rather than having the boost in the lower end and spinning through tires trying to get moving......
Old Jun 4, 2004 | 10:30 PM
Royal_T's Avatar
Ramius,
the .70a/r should still give me good top-end power right. Cause i was looking to get a .81 but they said they did not have that a/r anymore
Old Jun 5, 2004 | 10:46 AM
PharoNDmist's Avatar
I just picked up a T4/T4 with a super 60 A/R turbine and .81 exhuast side. What is so great about the Super 60 wheel??
Old Jun 5, 2004 | 01:06 PM
BigDogJonx's Avatar
Where do yall get off trying to say the maxima header is inefficient? "I have seen 1.6 liter B series fully spool a t3/t4 at 3000 rpm. " First off people seem to forget the word FULL SPOOL means nothing on a turbo, what psi we talking about? Cause technically full spool on a t3/t4 is about 2bar.
Explain to me how I start spooling the turbo at 1psi at 1400rpm? Ask bags533 if you dont believe me. I can be at almost 15psi by 3200rpm, how is that inefficient?
Dixit
Old Jun 5, 2004 | 04:13 PM
stephenlc's Avatar
It would probally spool even quicker with a smaller manifold, like a crossover pipe. Maximas are doing great! I am just saying other engines like the B18 make almost the same amount of hp as a maxima at a certain PSI. Give a take a PSI. But the Maxima makes alot more torque because Hondas don't really make any torque till the VTEC kicks in. They alredy have 500 - 1000 less lbs. than us, and I am just trying to get the upper hand on them. We have at least 20-30 fully built civics here in Houston, and probally twice that semi-built. Each running about 16 -30 lbs. of boost.
Old Jun 6, 2004 | 05:11 PM
IceY2K1's Avatar
What does that mean?
There are SEVERAL more variables that contribute, but it's NOT the OEM headers. The volumetric efficiency of the engine, displacement of engine, efficiency of the turbo/IC, length/volume of intake/exhaust piping, and especially the long crossover pipe that feeds the turbine that our V-engines require.
Old Jun 6, 2004 | 05:16 PM
stephenlc's Avatar
I meant smaller as in size. I think a crossover pipe would be long, but not as long as a huge U.
Old Jun 7, 2004 | 05:01 AM
MardiGrasMax's Avatar
My experiance with a .81 non BB T4/60-1 was great until I tried to race a WS6.
With the .81 I would get 1psi at 3k & 10psi by 4.5krpm. Car felt fast! But what I founf out was that the spool up time is more critical than the rpm where you get boost. I was next to this WS6 and we both hit it at the same time, he jumped me good! When I spooled up I could hang but he was 2 cars out already, awefull! I have decided to go with a .58 turbine.
Old Jun 7, 2004 | 07:20 AM
Bags's Avatar
What mods did the WS6 have matt?
Was it a T-top? Were they removed?
I ran a friends WS6 and I pulled on him slightly from 2nd gear @45 mph but he would even it back up in 4th
Old Jun 7, 2004 | 07:27 AM
Bags's Avatar
I met a guy yesterday with the next size down t3/t4 than me. He has 1 psi @ 3800 rpm and full spool of 22 psi @ 4800 rpm in 3rd gear, with a 8000 rpm redline.
He makes ~420 whp, but I have 1 psi @ 2600 rpm and full spool 7 psi @ 3400.
I make more WHP than him until 4300 rpm
Old Jun 7, 2004 | 08:30 AM
Bags's Avatar
Turbo ITR dyno from TX...
Old Jun 7, 2004 | 08:32 AM
Bags's Avatar
You can KEEP that. It's like 2 different cars.
The 1 below 5000 rpm and the one above 5000 rpm.
Old Jun 7, 2004 | 11:40 AM
It was red with a license plate that read somthing like WS6GIRL, a dude was driving with a girl in the passanger seat. It was some time back, I cant remember if it had T's or not.
Old Jun 7, 2004 | 03:21 PM
Bags's Avatar
ok, I was just curious....
I'll talk to you more about it since your here
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
minsbang
Sep 11, 2015 08:48 PM
nissan99
Sep 11, 2015 03:52 AM
ballerchris510
Sep 10, 2015 09:35 PM
