Secret to removing injectors from fuel rail?
Old Jun 7, 2004 | 09:13 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I'm trying to remove similar injectors to the 95-99 Max(ie Sentra) from the fuel rail that's already been uninstalled, but they're being stubborn. I'm sending them out for cleaning/flow testing, so I don't want to *** them up more then I have too.
I think a bench vise would make this simpler, but I don't have one.
Any tips/advice? And yes I removed the injector "caps".
Old Jun 8, 2004 | 04:07 AM
JAY25's Avatar
Grab some WD-40, grab some pliers. Spray the WD-40 between the injector and the fuel rail to get the rubber seals nice and slippery. After you have sprayed the WD-40, gently twist the injector left and right, left and right. Grab a screw driver, stick the flat screw driver between the injector and fuel rail and twist. Be very careful as the injector will eject high in the air if you twist the screw driver very hard. Thats how you pull injectors off without damaging them. Yes a bench vise is a great place to sinch down the fuel rail.
Old Jun 8, 2004 | 07:19 AM
IceY2K1's Avatar
Thanks Jay.
They turn back and forth, but fockers are in there tighter then a sumbich.
Old Jun 8, 2004 | 07:49 AM
JAY25's Avatar
thats why you spray WD40 or liquid wrench, so the rubber seals become slippery.
Old Jun 8, 2004 | 08:01 AM
IceY2K1's Avatar
I'll definitely try that tonight.
Old Jun 8, 2004 | 09:04 PM
IceY2K1's Avatar
Thanks Jay...worked like a fricken charm.
I chose WD40, since the liquid wrench said includes "teflon". Not sure if that matters, but something I don't want getting inside the injector since I'll be reusing them.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
