Stillen Part #...Bolts ??
Old Jul 1, 2004 | 12:36 PM
matty's Avatar
Im looking to order some bolts for the crank case on the side of the engine holding the plate on...the bolts for the SS Feed line I found..
(2) M6x1.0x30MM HHCS 407000-46
Stillen needs a part number before I go and order them ?? I think I need about 4 and I already tried a hardware store
Hardware – Intake tubes Assembled
by__________________ Date ___________
(1) Silicone hose, Black - 90°, supercharger to cross
over tube 407000-13
(1) Silicone Hose, Blue - MAS to 90° Ř 3.00 tube
407000-12
(1) Silicone hose, Blue - 90°tube to Throttle body
407000-12
(4) Hose clamp #48 Hard pipe/Mas/Throttle body
407000-19
(1) Blow Off Valve Assembly with adapter 407000-24,
-8
(4) Cable Ties, 11” Black 405030-6
(2) Aluminum spacers – Stand off to valve cover
407000-17
(1) M8x1.25x40mm Flange Head CS 407000-69
(1) M8x1.25 Prevailing Lock Nut 407000-86
(8) M6x1.0x55mm Hex bolt 407000-45
(8) M6 lock washer 318109
(2) M10x1.5x60mm Hex bolt 407000-33
(2) M10 flat washer 407000-34
(6) M6x1.0 Nyloc nuts 402993
(12) M6 Flat washers 318110
(6) M6x1.0x25mm Hex bolt 402990
(2) M6x1.0x40mm Hex bolt
(2) Hose Clamp #40 – Supercharger to 90°hose
407000-18
This is a list of bolts I found in the FAQ's...I may not be in so if someone knows more than me, chime in please
-matt
Old Jul 1, 2004 | 02:27 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
go to autozone or pep boys
you can find all those m sized bolts
Old Jul 1, 2004 | 05:19 PM
matty's Avatar
I kinda just want to find out what ones are for the plate to the engine, what ones are used for the charge pipe, and so on and so on.....
-matt
Old Jul 2, 2004 | 11:45 AM
slimer's Avatar
oh,
m6 are the small ones that fit into the timing chain cover
the m10 ones fit into the motor mount.
and i think that the m8 ones fit through the pulley and go into the s/c. im not 100% positive on the m8 tho.
Old Jul 2, 2004 | 09:18 PM
matty's Avatar
There are Three different sizes of the M6 Bolts ??
What are these... lol
Old Jul 4, 2004 | 02:12 PM
matty's Avatar
bump
-matt
Old Jul 5, 2004 | 08:29 AM
matty's Avatar
Anyone know the Length Bolts for the :
--**S/C Plate to Timing Cover**
-- S/C Charge Pipes to Vavle cover
-matt
Old Jul 5, 2004 | 10:54 AM
slimer's Avatar
theyre all in mm, those are the different lengths of m6 bolts
25mm
40mm
55mm
Old Jul 5, 2004 | 10:59 AM
matty's Avatar
Yea I know there in mm and there are those lengths, What bolts are for what purpose during the install ??
Here is the list with part #
Hardware –
Old Jul 5, 2004 | 02:23 PM
slimer's Avatar
i told you the m6 ones hold the plate to the timing chain cover and the m10 go into the motor mounts
they fit throught the plate into the engine
Old Jul 5, 2004 | 02:32 PM
matty's Avatar
what are those M6's used for ??
-matt
Old Jul 6, 2004 | 12:18 PM
matty's Avatar
Ok i know that the ones for the S/C plate to the car is (8) M6x1.0x55mm Hex bolt 407000-45...now what are these used for ::
There shorter M6 bolts
Old Jul 6, 2004 | 09:50 PM
matty's Avatar
Nobody know what the M6X25 and the M6X40 Hex bolts are used for
Old Jul 7, 2004 | 06:38 PM
matty's Avatar
bump...sorry to be a pain in the a**
Old Jul 7, 2004 | 09:15 PM
slimer's Avatar
the m6x25 is the short one that fits thru the plate and goes into the stand off bolt that is a PITA to get to (hole 18?)
the m6x40 is the one that goes through the plate that goes into the stand off bolt thats above the alternator bolt.
i hope im helping.
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Maxboy23
Sep 4, 2015 06:04 PM
