Help!!!! Need Pistons And Rods For A Ve Turbo!!!!
Old Aug 1, 2004 | 10:04 PM
espimax's Avatar
I Need To Know If Any One Has Done The Internals On A Maxima If So What Kind Of Pistos And Rods Are You Using And $ Also Were To Find It, I What To Go 8 To 1 Compression, And I Also What To Kept It Stock Bore, Whats Best For The Maxima Any Posible Help Will Be Apreciated. Thanks, Espimax
Old Aug 1, 2004 | 10:42 PM
Bags's Avatar
VG Ridah's Biatch Hoe
http://www.jepistons.com/
http://www.grpconrods.com/
http://www.crower.com/cat/import/mitsu/rods.shtml
Old Aug 2, 2004 | 06:55 AM
stephenlc's Avatar
I think you should check ebay for Z31 pistons and rods. And try some Z31 sites. You might have to bore the block a little.
Old Aug 2, 2004 | 07:27 AM
mtcookson's Avatar
Z32
You should be able to use Z32 pistons on the VE rods or you can just use the Z32 rods and pistons. the vg30e, ve30de, and vg30de/tt all have the same bore and stroke.
Old Aug 2, 2004 | 10:17 PM
dmontzsta's Avatar
Ford Only.
Z32 Rods are the same as your VE rods. Just get yourself some Z35 8:5:1 comp pistons and you are done.
Old Aug 3, 2004 | 06:56 AM
mtcookson's Avatar
I'd actually get 9:1. I thought .5 compression ratio loss made a pretty big difference on the low end, going from 10:1 to 8.5:1 will make it feel like a dog on the low end. Also, most forged pistons made for the Z32 are 9:1 from what I've seen.
Old Aug 3, 2004 | 07:03 PM
espimax's Avatar
i order my pistons and rod
i order the pistons from waesteco and the rods from eagle, with 8.1 comp. thanks all for the replay and help.
Old Aug 5, 2004 | 07:33 AM
dmontzsta's Avatar
Ford Only.
no problem, just make sure you crank up the boost, cause you will need it now with that low compression. I would just run a stock VE 10:1 and keep the boost below 12psi.
Old Aug 5, 2004 | 10:08 AM
Bags's Avatar
cool. Please keep us updated if you can. Most of us in here enjoy reading and seeing pics (HINT HINT) of motor projects.
Old Aug 5, 2004 | 10:15 PM
espimax's Avatar
that`s how i blew the motor i wen to 15psi it fell great but about 145mph on 4th gear boooom she wen so now i`m doing another eng. over, i wen to 8.5:1 they did not have the 8:1 on stock, i keth you posted i`m also adding a second inline gas pump, the ttz in tank just did not cut it.
Old Aug 5, 2004 | 10:17 PM
espimax's Avatar
ohh i wen 15psi wen my mechanic spesificly and clearly said kept it at 8psi untill we dyno it, well i gess it is adicted!!! now i`m paying the price.
Old Aug 6, 2004 | 08:30 AM
subs1000w's Avatar
good god you took it to 15psi with out tunning it. sorry buddy but i have no mercy for you that was your own dumb fault
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
