So Hal are you runing 355cc injectors ? Or did you just change the injector size on your standalone in order to fool the computer into runing leaner ? Why do you run a FMU with a stand alone ? What kinda stand alone are you runing ? Does it still have all the emissions controlls built in- like EVAP and missfire monitoring ? I'm currious as in IL they do readiness code testing and MIL testing, if the codes are not set or you have a check engine light then they fail ya.
So your running an FMU and 555's? Are you still on a single fuel pump? If so watch the fuel pressue it may drop off when you start cranking up the boost
Nope, dual in tank Walbro
Cool!
What scan tool can I use on a 89 Maxima? Who makes it and approximate cost?
So the Warbo pump (like the GN's Have) works? Factory Fuel pressure regulator or aftermarket? Awsome setup.!!!! |
The GS34X pump can support upto 720cc/min if you crank up the voltage to 16V: http://www.stealth316.com/2-fuelpumpguide.htm
It can support 550cc/min, if you upgrade the wiring and your charging system can provide 13.5V or more depending on your fuel pressure needs. |
Nissan Consult. Seen them for on ebay for oh.. a few thousand. Your maxima is OBDI. This is before the Gov't mandated universal diagnostics for all automakers (all 1996+ automobiles are obdII compliant and can use obdII scan tools)
I've only seen a Consult-I on eBay, have you seen a Consult-II?
Let me know if you do.
Why would you want one?? I mean they are cool but not $$$$ cool!
Yes, but depends on the cards included and if you can download updates from the Nissanusa website or not.
I must have Hal mixed up with another Maxima.org member who is going to be or is runing a stand alone and gonna sell it for some .org memebers. Even with Emanage you should be able to ditch the FMU. I have a 240 with a KA runing 555s and TTZ MAF at 400WHP with no problem on stock ECU and Emanage- I just finished tuning it for my friend as no shops around this area know WTF they are doing with Nissans and cost him an engine.
400whp on a KA...damn.
Can you explain how you squeeze 400whp out of four 555s withOUT a FMU? Even at 100% duty cycle and NA stringent 0.50 BSFC, that's not possible.:confused: |
I run 4 bar of fuel pressure :) Nismo FPR with a Walbro in-tank, on Tomei 555cc injectors pulling air in via a Z32 TT MAF. You can get 300WHP from a set of 370ccs at 4 bar of fuel pressure. I do that daily with my G20 on a T25 turbo.
555cc@58psi --->640cc/min, which using again 100% DC and NA stringent 0.5 BSFC is good for 487bhp or 415whp assuming 15% drivetrain loss.
Alright, that's close, but damn close.;) |
Okay I rounded off the 400WHP # :) its actually 387WHP, but its very close to 400WHP, and I'm sure if I where to get the turbo extrude honed it would hit 400WHP at that same boost :) I actually run 61psi on the KA and my SR. Works like a charm and the injectors have been happy for a long time now, no problems. Lets see 740cc injectors for 500 bux, or Nismo FPR for 90 bux... ehh I take the FPR :)
"400WHP" does sound better then "387HWP"....LOL.
Hmmn....61psi all the time and no leaks, fuel pump crap outs, etc.... Interesting...very interesting. |
Originally Posted by hlh0501
Update for anyone who cares:
I found out my pressure switch for MEVI has failed, it is allowing some vacuum to creep by... so my MEVI is always open right now. I have to get a new one and throw it on - then it's off to the dyno (and/or maybe track) for baseline numbers
I did have something weird happen earlier, the car slowly started running more and more rich , even idling. It got to the point it was choking just sitting at a red light, AF dropped to 9:1 and eventually got to "TOO RICH" on the wideband.
Also, can I get a link to the e-manage forum spanishrice is referring to. |
Originally Posted by pimpjuice
I am curious as to when you want your mevi open and when you want it closed.
Since we don't have the same fuel setup, maybe its e-manage related...who knows. Also, can I get a link to the e-manage forum spanishrice is referring to. I played with it tonight, and the difference between a 4000 and 5000rpm changeover made 4mph diff. in the 1/4. Best I've found is around 5200ish to allow vacuum to it allowing it to open. I doubt its emanage related, bc even when I connected the MAF back to stock (no emanage) and left all tables at 0 it was loading up extremely bad. I think my FMU is gone. |
Wideband log:
Made some changes tonight, and went a little too rich, but nonetheless Steady 10.x af under boost Cruises at ~13.5, and idles around 14. http://www.fastmaxima.com/tmp/9-21%20wideband%20log.gif Emanage log: shows rpm in red, +MAP in black, retard in yellow, fuel in blue http://www.fastmaxima.com/tmp/9-21%20emanage%20log.gif MUST PUT SPRAY BACK ON!!! 1.3 second respool on shifts, ahhhh |
Nice....
Are those two spikes to ~13.1 on your AFR when you first go to WOT? |
[QUOTE=hlh0501]Wideband log:
Made some changes tonight, and went a little too rich, but nonetheless Steady 10.x af under boost Cruises at ~13.5, and idles around 14. http://www.fastmaxima.com/tmp/9-21%20wideband%20log.gif QUOTE] Is this at wide open throttle, what are the spikes from. I don't like those 13:1 or higher spikes, make my car go boom. |
Originally Posted by IceY2K1
Nice....
Originally Posted by Stephen Max
I've seen the afr do that during shifting.
Nice....
Are those two spikes to ~13.1 on your AFR when you first go to WOT? I guess I should have stated, the two flat lines are 3rd and 4th gear. and right before that, where it bounces from 12->10->12 is 2nd gear spinning like crazy as I tried to feather the gas. |
I thought that at first, but figured it would go rich, since you have an open atomosphere BOV, ie metered air is released, so there is excess fuel.
Wideband log:
Made some changes tonight, and went a little too rich, but nonetheless Steady 10.x af under boost I try for a steady 11.5 |
Ice, my MAF is after the BOV, so no metered air is released :)
I had it tuned to 11.8 (my goal) and tinkering plus a FP problem had me to 10.5 last night. I think it is near 11.0 now |
When will the turbo Y pipes be availible ??? I'm ready to do some nasty things to my new engine on the engine stand.
:shiner: :shiner: :shiner: :shiner:
jez, once youre done with the "new" dek, do you want to tinker with your ae vi and my de?
slimer, I got home yesterday and the dude revoked my bid- as I was the only bidder. Looks like every auction he had up was a fluke. It showed alot of diff engines for sale n stuff but nothing went through. But I am getting another DE-K so I can do some tinkering to it internally before I put it in the car.
© 2024 MH Sub I, LLC dba Internet Brands
