How do I know the trim of my compressor wheel?
Old Sep 25, 2004 | 10:16 PM
Nealoc187's Avatar
SLOW
I'm trying to figure out the trim of my wheel. I bought this turbo used from on_alert and I have figured out the A/R of both the compressor and turbine side (.60 and .70 respectively) but I don't know how to find out the trim of the wheel. There is what looks like a stamp (not a metal stamp, but an ink stamp) on the compressor wheel, it is kindof smudged but there is definately a "46" on there, and what looks like a big smudged decimal point or some other marking in front of it. This would lead me to believe I have a 46 trim (which is an existing trim for garrett compressor wheels I found out) but does anyone know if this is what that stamp indicates or am I totally off base.
Old Sep 25, 2004 | 10:48 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Call garrett and see what they say.. I'd think measuements would work.. but there may be more to it than that.
Old Sep 25, 2004 | 10:54 PM
Nealoc187's Avatar
SLOW
I did some more research and came across something that said its the (inducer area/exducer area) x 100
however to measure the radius and thusly calculate the area of the exducer i would have to take the turbo apart... is it safe to just take a turbo apart. i've never looked into that before.
Old Sep 25, 2004 | 11:20 PM
Bags's Avatar
Take the housing off, no problem.. MAke sure you don't damge the O ring.
DO NOT REMOVE THE SHAFT NUT/BOLT. LEAVE THE CENTER SECTION INTACT.
If you disassemable the center section/shaft, you ned to have it re-balanced.
Links
http://www2.upatsix.com/faq/LMturbine2.htm
http://www.engsoc.org/~ethor/turbapart.htm
Hope that helps
The Frye
Feb 3, 2019 08:34 AM
05' MaximaMan
Oct 8, 2017 06:36 PM
BkGreen97
Apr 2, 2016 05:47 AM
tgreen
Oct 18, 2015 06:18 PM
brichi
Sep 14, 2015 05:23 PM
