Quick question about MAP sensor and boost
Old Sep 28, 2004 | 09:50 AM
deezo's Avatar
In order to run high amounts of boost, will you need to upgrade the MAP sensor to one that allows your setup to run at 1 bar or above? Are are any of you close to running 1 bar and if you are are there upgrades available or will you need to run a MAP sensor for the 300ZX TT?
Just something that crossed my mind in class yesterday while talking to my instructor (car nut from corvetteforums.com).
Old Sep 28, 2004 | 10:16 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nobody is running a MAP sensor yet, just MAF.
Hal is thinking about running one with his standalone.
Old Sep 28, 2004 | 10:48 AM
hlh0501's Avatar
I run a 3bar GM map sensor. I would have preferred using a 2bar map sensor for the added precision, but I knew I would be exceeding 2bar. Keep in mind, 1bar = atmospheric
So, my map sensor reads up to +29psi of boost
I am running ~2.15bar presently, 1.15 relative
I use MAP on my fuel map bc the MAF maxes out, (although I purchased a Z32 MAF, I will continue using MAP)
and I use it on my ignition map so I can retard a set amount of timing based on kpa vs rpm.
I don't have a standalone.
Old Sep 28, 2004 | 10:51 AM
hlh0501's Avatar
oh and i just reread your post. Sounds as though you are under the impression our cars run off a 1bar map factory? (which would not see boost)
We use MAF
I added MAP for tuning.
Old Sep 28, 2004 | 12:14 PM
deezo's Avatar
Got it. Thanks.
Cotozic
Jun 28, 2017 08:01 PM
Jcof88
Sep 9, 2015 03:11 PM
soloist3
29
Sep 1, 2015 03:47 PM
classymax420
Aug 6, 2015 06:35 PM
bassmann
Aug 3, 2015 07:53 PM
