Those turbo'd w/emanage
Old Sep 28, 2004 | 10:31 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
What settings did you guys use for the anti-stall map on the emanage?
Also, if you have 555 cc injectors - what numbers did you guys use for injectors b/a. What settings did you guys use for partial throttle... I'm running pretty rich but not so bad now since i've tweaked it a little.
Old Sep 28, 2004 | 10:40 AM
hlh0501's Avatar
I don't use antistall... and injectors, just the before and after values.
As far as curing partial throttle problems, you could switch to MAP vs RPM and leave everything from vaccum -> +20kpa alone. Thus allowing the stock ecu and maf to deal with idle and cruising.
Old Sep 28, 2004 | 12:56 PM
turbomax97's Avatar
I'll try that... anyone on the antistall?
Old Sep 28, 2004 | 06:07 PM
MardiGrasMax's Avatar
Check you MAF voltage at idle, not the RPM.
Set the colom all the way to the right a 100rpm below the idle point and at .02v les voltage. The work to the left in 50 rpm incraments and drop .02v per colum. Thats a ball park way of doing it. It will take some fine tuning from their.
Old Sep 28, 2004 | 07:42 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Added to sticky Thanks MATT
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
