A32 ECU+Z32 MAF+500cc+adjustable FPR?
Old Oct 12, 2004 | 02:30 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Possible to idle? Anybody care to test this?
Bags is running ~400cc injectors without turning down the base fuel pressure, so I'm hoping to turn down base fuel pressure to ~28psi for 500cc or ~23psi for 550cc. It should work, but atomization/injector on-off time might be an issue.
Just trying to come up with a non-JWT/eManage solution to running superdave2's injectors with just an AFC and FMU.
Old Oct 12, 2004 | 02:50 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yeah, i would like to know too because i already have most of the components of that system. (adj fpr, afc and a the crossover pipe for the z32 maf)
would a q45 maf work?
Old Oct 12, 2004 | 02:54 PM
IceY2K1's Avatar
Maybe...GOOD point.
There are even larger MAFs out there, so maybe one of them can compensate for the % increase in injector size.
I'd bet the 5.6L Titan uses a hell of a MAF.
Old Oct 12, 2004 | 02:56 PM
slimer's Avatar
thats what i was thinking.
Old Oct 12, 2004 | 04:20 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Originally Posted by IceY2K1
Maybe...GOOD point.
well just remember, like I posted, the Airflow % readings were within .1 Volt @700 rpm and .2 volts @900 rpm.
Old Oct 12, 2004 | 04:23 PM
IceY2K1's Avatar
On cold starts I shoot up to ~1200-1300rpm and then slowly drop down to ~900rpm.
The MAF voltage is non-linear, so a 0.1-0.2V could be enough.
Old Oct 12, 2004 | 05:19 PM
slimer's Avatar
mine starts up around 1k
Old Oct 13, 2004 | 09:17 AM
IceY2K1's Avatar
Okay....anybody with an eManage, Z32 MAF, 500+cc injectors, and an adjustable FPR willing to set your A/F corrections to zero and play with fuel pressure to see if she'll idle?
Old Oct 13, 2004 | 09:32 AM
Redmax's Avatar
Redlinemax Owner
I'd do it, but i don't have the z32 maf.
Old Oct 13, 2004 | 09:43 AM
I30tMikeD's Avatar
Is the only difference in the MAF's the size of the tubing? Or is the sensor actully different?
Old Oct 13, 2004 | 09:50 AM
IceY2K1's Avatar
Size is the same...sensor is different.
Old Oct 13, 2004 | 09:55 AM
IceY2K1's Avatar
What whp are you pushing?
Old Oct 13, 2004 | 11:01 AM
Redmax's Avatar
Redlinemax Owner
welll Ice, my current setup is a32 maf 370 injectors, and 10psi untuned which I think is about 320 whp but My 590 cc injectors from i30miket will be in tomorrow and I will turn up the boost. new fuel pump today new injectors tomorrow and new clutch on the weekend
Old Oct 13, 2004 | 11:33 AM
I30tMikeD's Avatar
What are using to tune with?
Old Oct 13, 2004 | 12:10 PM
IceY2K1's Avatar
Well you definitely need a Z32 MAF or larger then to keep a metered airflow referenced system, since the A32 MAF is outflowed at ~290whp.
Old Oct 13, 2004 | 12:48 PM
Redmax's Avatar
Redlinemax Owner
well i am tuning with the emanage and have the emanage map sensor so I don't have to go to a bigger maf, its just a little easier to tune with thte larger maf
Old Oct 13, 2004 | 01:15 PM
IceY2K1's Avatar
I don't believe that is true, but I could be wrong.
The way I understand it, you can use the MAP sensor to tune past the MAF limits, however from then on you're running "blind". In other words, whatever you set it and forget it at on the dyno, if anything changes, ie weather/boost/etc. that causes more/less air above the MAF limit, the system won't compensate.
I guess it's no worse then a non-airflow referenced system, however personally I think that's not the way to go. I'd rather have the MAF within range, so it can dynamically meter any increases/decreases in airflow and the ECU will automatically compensate.
Old Oct 13, 2004 | 01:21 PM
Redmax's Avatar
Redlinemax Owner
Well, that's why i said I would rather the f150 maf if it works. then tune from there
Old Oct 13, 2004 | 01:23 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
and IMO its not a very efficient method if a larger MAF option exists. you'll still need the larger MAF in the long run...the Greddy Pressure sensor does not adjust for anything when you exceed stock MAF voltage..it only allows you to view "estimated" voltage and then tune it yourself from that, it does no self tuning as many believe. if you're doing all that extra work by then, comparing the sensor voltage from the datalogs and then applying it to making your map...you could get a Z MAF and be say screw all that and just make your tuning runs as normal.
EDIT: I guess I take too long to type...Ice said the same thing. I'm pretty sure I saw NAPA selling the aftermarket 5.0 or 4.6L Ford MAFs for $150. at this point, I sguess al you can do is try it
Old Oct 13, 2004 | 01:40 PM
IceY2K1's Avatar
I think Mardi will be pioneering this AGAIN...as usual.
Old Oct 14, 2004 | 09:58 AM
slimer's Avatar
i would, but i need to use another car. i might steal one of my parent's cars when they go to vegas in 10 days.
does anyone want to let me borrow some injectors?
i only live 20 mins away from mike, maybe i could "convince" him over a drink or two
Old Oct 14, 2004 | 10:17 AM
IceY2K1's Avatar
Hey Mike...how about that?!?!?
This COULD increase sales for your brother. I know others are interested in a non-JWT/eManage route.
Old Oct 14, 2004 | 11:20 AM
slimer's Avatar
he's just mad that i wont post up the vids of him beating me at the track.
if anyone can host--pm me
Old Oct 14, 2004 | 01:03 PM
I30tMikeD's Avatar
There is a boosted Max owner who is going to test these out already, and I believe they will be tuned with eManage. Dave finished 30 injectors last week and they all sold within a couple days, he is finishing 40 more this week.
Old Oct 14, 2004 | 01:50 PM
IceY2K1's Avatar
Without the eManage right?
Old Oct 14, 2004 | 02:08 PM
I30tMikeD's Avatar
No, with eManage from my uderstanding. I don't know about running that large of injectors with just an SAFC....but I wouldn't really be the one to know for sure.
Old Oct 14, 2004 | 02:31 PM
IceY2K1's Avatar
We are trying to find someone to test that a Z32 MAF and adjustable FPR can idle the 500cc's.
According to Bags 400cc example, turning down base fuel pressure COULD work.
Old Oct 14, 2004 | 02:48 PM
slimer's Avatar
ill give them back, we can even do the install at your house. i would just like to see if the z32maf/a32 ecu combo would work.
i have already done the math. dave's injectors are 33% larger than the 370's so i would have to drop base fp to about 26 psi.
Old Oct 14, 2004 | 03:53 PM
I30tMikeD's Avatar
I am not the one who does the modification to the injectors....and my brother lives 800 miles away from me.
Old Oct 14, 2004 | 04:16 PM
IceY2K1's Avatar
Well that sucks...so there is no way he could mail you a set to test try?
Old Oct 14, 2004 | 04:34 PM
I30tMikeD's Avatar
I will see.....he is having a hard time keeping up with demand right now
Old Oct 14, 2004 | 04:42 PM
IceY2K1's Avatar
Good...hopefully one of them will attempt it.
Old Oct 14, 2004 | 05:22 PM
Bags's Avatar
BTW.. I have learned if the car cranks and you shut it off instantly or almost cranks and you stop cranking it, it then is almost flooded. It's VERY hard to start. I verified this once by accident and reverified 3 times on purpose.
Turn the key until it starts in 50 deg weather, no problem. It's getting colder here, so we will see what happens.
Again, just FYI
Old Oct 15, 2004 | 10:15 AM
IceY2K1's Avatar
That will improve by turning down base fuel pressure.
Again, just FYI
Old Oct 15, 2004 | 12:03 PM
slimer's Avatar
i know mike, im just giving you some grief. funds will come in about two weeks to be able to buy them.
Old Oct 15, 2004 | 12:06 PM
Bags's Avatar
right, just throwing out info about my setup. I don't want everyone to think it can't cause a problem
Old Oct 15, 2004 | 12:30 PM
IceY2K1's Avatar
StephenMax did the same, however with a SC which moves more air at idle and 370cc.
Old Nov 10, 2004 | 08:14 AM
IceY2K1's Avatar
Come on....anyone try this combo yet?
If not, what's the hold up with superdave2 selling 5XXcc injectors for so cheap/easy?
Old Nov 10, 2004 | 06:38 PM
Bags's Avatar
get me the injectors and I'll try it
Seriously, if I had the $$$ I would. If I knew someone with 500+cc injectors, I'd try it out
Old Nov 11, 2004 | 09:15 AM
IceY2K1's Avatar
Fock, I can't swing $300 right now or I would.
