A little help if possible please: trying to set up the 2.87 pulley i have this
Old Oct 15, 2004 | 07:50 PM
mighteatyou's Avatar
Basically i am going to run the 2.87 Pulley on the V2 supercharger.
I have all bolt on mods, suspension, flywheel, clutch,mevi,headers,y,catback,ect ect ect etc etc. what i am really worried about is the fuel system and the tuning of the car after the install.
so far i have the following covered:
Stillen V2 Supercharger Kit
Place Racing Motor Mounts
NGK type BKR6E-11 Copper Spark Plugs
HKS Blow-off valve
3 POD 2 1/16 Pillar
Defi Boost Gauge
Defi EGT Gauge
Defi Fuel Pressure Gauge
ASP tension & Idle Pulleys
2.87 S/C Pulley
2.87 S/C Belt
Walbro 255lph Fuel Pump
Z32 Maf
Apexi SAFC II(black)
AEM adjustable Fuel Pressure Regulator
None of these are installed currently they are all sitting here in front of me at my house or on the way in the mail.
Basically after i get all the pieaces i want too call up jim wolf and get the ECU programed for the s/c,mevi,Z32 maf, and i also planned on getting the injectors from JWT unless anyone recommends differently. also should i get the 550cc injectors ? can i?
Please i am open to any comments and sugestions to get the job done
please help me out guys no flames
Old Oct 15, 2004 | 08:20 PM
iansw's Avatar
You could get the 550cc Injectors, but you'll be fine with the 370cc's on a 2.87" with no Nitrous added.
Looks pretty good. Nearly the same exact setup I have.
You need a MEVI however.
Old Oct 15, 2004 | 08:24 PM
Stephen Max's Avatar
Ian, are you running the BKR6's or the 7's?
Old Oct 15, 2004 | 08:25 PM
iansw's Avatar
6's...............
Old Oct 15, 2004 | 08:27 PM
i already have the MEVI , is there any last minute tips you can give me?
Old Oct 16, 2004 | 08:59 PM
michaelnyden's Avatar
I'm not expert, but it looks like your set
Old Oct 17, 2004 | 12:53 PM
crewchief264's Avatar
Have you thought about Intercooling it? If so check out my sight!
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
