leanest and richest cylinder
Old Oct 22, 2004 | 12:03 PM
Redmax's Avatar
Redlinemax Owner
I bought the injectors from mikes brother and the injectors have quite a span in the amount of cc's they can flow. but which cylinder is the leanest and which is the richest so i know which injector to put where.
Old Oct 22, 2004 | 12:07 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
huh?? explain...does each have a different flow rate? not sure I follow
Old Oct 22, 2004 | 12:09 PM
Redmax's Avatar
Redlinemax Owner
Yes each has a different flow rate the highest being 590 and the lowest being 569
Old Oct 22, 2004 | 12:36 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Sounds like more then "3% tolerance" as promised?
Originally Posted by I30tMikeD
After modification, the injectors are sonically cleaned, back flushed, rebuilt with OEM seals, fitted with custom pintle cap, checked for leaks, analyzed for spray pattern, flow tested, and matched to a 3% tolerance.
So, this is a balanced/matched set.* What does this mean?* It means all the injectors flow within 3% of each other.* Even brand new OEM injectors can vary in flow as much as 10%.* Balanced/matched injectors allow more precise tuning on your engine to*yield higher and safer horsepower.*
Old Oct 22, 2004 | 12:39 PM
superdave2
What?!? I don't understand, I am looking at a copy of your injector report right now and the lowest flowing is #M04-019 which flows 569cc/min and the highest flowing is M04-015/M04-016 which both flow 590cc/min. This is a 3% variable as advertised.
If I accidently sent you a wrong injector let me know, I will send you a replacement today.
Old Oct 22, 2004 | 12:46 PM
Redmax's Avatar
Redlinemax Owner
I am taking care of this with dave now I will check my sheet when I get home tonight. he is actually more than likly right the lowest one is 569. I did not have the sheet with me. when i posted
Old Oct 22, 2004 | 12:51 PM
superdave2
Check your report, you should have the following injectors...
M04-015
M04-016
M04-017
M04-019
M04-023
M04-026
Old Oct 22, 2004 | 01:00 PM
DA-MAX's Avatar
yeah, it makes sense now, I wasn't thinking
Old Oct 22, 2004 | 01:08 PM
IceY2K1's Avatar
That does bring up a point, but probably negligible with only a 3% variation, ie which cylinder(s) get the higher flow vs. less flow injectors.
I'd say...
135<~~Fuel in
246~~>Fuel out
6<~~Highest
1<~~Lowest
Old Oct 22, 2004 | 03:52 PM
bruteMax's Avatar
nice that all your injectors are well over 550cc.
Old Oct 22, 2004 | 08:59 PM
mtcookson's Avatar
I'd say...
135<~~Fuel in
246~~>Fuel out
6<~~Highest
1<~~Lowest
i'm not sure it'd really matter but basing off of the first three you had wouldn't you want to go:
or is it the driver's side cylinders that tend to run a bit leaner?
Old Oct 23, 2004 | 09:26 PM
Stephen Max's Avatar
I'd say...
135<~~Fuel in
246~~>Fuel out
It's the other way around for 4th gens.
135 ~~> flow out
246 <~~ flow in
Old Oct 24, 2004 | 07:19 AM
I30tMikeD's Avatar
Did you figure out if the injectors were the correct ones?
Old Oct 24, 2004 | 12:05 PM
Redmax's Avatar
Redlinemax Owner
yes they were correct it was my fault
Old Oct 25, 2004 | 10:36 AM
IceY2K1's Avatar
Yes, 6-4-2-1-3-5. Thanks for fixing that.
Old Oct 25, 2004 | 12:29 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i always seem to have my misfires on 4
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
