OK stupid question
Old Nov 3, 2004 | 01:12 PM
LatinMax's Avatar
OK stupid question
I know that I know the answer...but I am having a memory laps at the moment.
What is the factory injector size on the 2000 Maxima?
Help...this is one of those moments that my kids call me oooooolllllld.
Old Nov 3, 2004 | 01:31 PM
SonicDust187's Avatar
290cc
12345
Old Nov 3, 2004 | 01:33 PM
LatinMax's Avatar
Thanks........
Old Nov 4, 2004 | 08:28 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Gabriel,
You trying to tune your PE510s with the eManage?
Old Nov 4, 2004 | 08:24 PM
LatinMax's Avatar
Yes, why any suggestions?
Old Nov 4, 2004 | 08:29 PM
Larrio's Avatar
The Definitive AE Master
i guessing this might have to do with the talk that the injector size of 510cc is rated at the Z/G35/2k2maxima fuel pressure which is higher than the vq30de. So you might have to tell emanage a slightly lower number. How to calculate this I don't know
Old Nov 4, 2004 | 08:36 PM
LatinMax's Avatar
But I am running a after market fuel pressure reg before the FMU...So I could make it the same base line fuel pressure.
Right?
Old Nov 4, 2004 | 08:56 PM
Larrio's Avatar
I am unfamiliar with e-manage, i'll let the experts handle this
Old Nov 5, 2004 | 07:54 AM
IceY2K1's Avatar
Yes, Larry hit it on the head.
I was just thinking that *IF* you get to a dyno and it's running a little lean, try using 290cc->470cc, so the eManage won't be pulling back as much. However, if you're using the eManage injector harness and using the additional injection tables, it's a moot point, since you'll be compensating.
What's your setup and progress so far?
Old Nov 5, 2004 | 08:33 AM
LatinMax's Avatar
I am welding the pipes today for the IC, then need to put in the J&S, and either build or buy a water injection system.
I also need to guy a wideband with gauge.
Then tune.
Also The new body kit (old kit with more modds don to it) go to the fiberglass mold guy so that we can get the molds done, then we will start mass producing them.
Old Nov 5, 2004 | 09:33 AM
IceY2K1's Avatar
Are you still running the SC? If so, do you really need WI with your IC?
Woah, what's the bodykit going to look like?
Then tune.
Old Nov 5, 2004 | 10:04 AM
LatinMax's Avatar
still SC, but with a smaller pulley. And I rather be safe than sorry....so yes I plan on doing the IC with the WI.
I will have pics of the kit in a few weeks.
Old Nov 5, 2004 | 11:24 AM
IceY2K1's Avatar
2.67"?
I understand safe rather then sorry, however if you have a decently sized IC, you have nothing to worry about.
Old Nov 5, 2004 | 12:00 PM
matty's Avatar
Originally Posted by IceY2K1
2.67"?
how would you use such a small pulley without over spinning the blower ??
-matt
Old Nov 5, 2004 | 12:07 PM
IceY2K1's Avatar
Stock rev-limiter means 52854rpm, however I think Mardi pushed it beyond but only for short periods.
StephenMax hits 52XX with his 3" and 7200 limiter.
Old Nov 5, 2004 | 01:22 PM
LatinMax's Avatar
After detonating once already (new engine) I just don't want that to happen again.
I rather have it in and find that I don't neeed it than the later.
I figure it can't hurt.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
