What R 370 Injectors?
Nov 10, 2004 | 09:34 AM
What Are The 370 Injectors And Where Can They Be Purchased? Does Anything Need To Be Fabricated Or Changed To Use Them?
Nov 10, 2004 | 09:37 AM
370cc injhectors will allow more fuel per cylinder.
I belive when going up in injectors, some wiring will be needed to be done but thats about all.
Nov 10, 2004 | 10:12 AM
What most of us refer to as the 370cc injector is the Z32 Twin Turbo injector (also used in Silvias). Direct plug in, no modification needed to the injector or harness for A32 maximas/i30s.
http://forums.maxima.org/showthread.php?t=328401
Check the links for 370cc injectors. Any questions after that just post up.
Nov 10, 2004 | 11:52 AM
Quote: What most of us refer to as the 370cc injector is the Z32 Twin Turbo injector (also used in Silvias). Direct plug in, no modification needed to the injector or harness for A32 maximas/i30s.
Thanks for the informitive post
Nov 10, 2004 | 01:43 PM
thanks for the info fellas...i am assuming that the injectors off of a twin turbo 300zx is what these injectors came off of.
Nov 10, 2004 | 02:06 PM
95-96 Twin Turbo to be exact. Also came on red & black top SR20DET motors.
