Another Mevi Q
the 2k1 mod is a little more complicated than it looks. and it is probaly more pricey in the longrun. plus the mevi is equally as good above 5000 rpm and i dont care about losing low end power. to install the 2k1 plenum you need to use the lower intake manifold, have the butterfly plates removed in it, have the holes welded over, fabricate a 4 inch plate to bolt your IAC on to, use the 2k1 fuel rail, and fabricate a plate to bolt the throttle body on to it. among a list of other things.
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
