PFI Turbo Kit
Old Nov 13, 2004 | 12:25 PM
95stillenmax's Avatar
PFI Turbo Kit
what all extra stuff do you have to get, that dosent come with the kit, to run 10 P.S.I
SAFS?
Injecters?
Fuel pump?
thanks Brandon
Old Nov 20, 2004 | 08:36 AM
bump...........
Old Nov 20, 2004 | 09:47 AM
Jade95Maxima's Avatar
im planning on this kit also...there is another thread a couple pages back about a guy asking which parts...for sure 255plh walbro fuel pump and bigger injectors 370cc-555cc injectors probably...but i'll let the actual turbo guys answer better.
Tony
Old Nov 20, 2004 | 09:57 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
either way get 370's and 255lph walbro.
to be on the safe side i wouldnt get the fmu that comes with the pfi kit. dont get the safc and get an e-manage and a z32 maf
-or-
keep the fmu and get safc and buy the J&S safeguard
Old Nov 20, 2004 | 02:58 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
SAFS?
Injecters?
Fuel pump?
thanks Brandon
i'd upgrade from the vortech fmu to the cartech, stock injectors will work fine. To actually make the 10 psi, you need a 3 inch exhaust and either a 10 psi wastegate spring or a manual/ electronic boost controller. Fuel pump is absolutely mandatory. That is really all you "need" to run 10 psi although there's thousands of dollars of accessories that you'd want to get sooner or later to control/ monitor the setup.
Old Nov 20, 2004 | 04:29 PM
Bags's Avatar
VG Ridah's Biatch Hoe
http://forums.maxima.org/showthread.php?t=327382
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
