Head Gasket/ Manifold ?'s
Old Dec 16, 2004 | 02:20 AM
Oblongshapes's Avatar
First off, how many of you have blown a head gasket doing FI?
Also, does the intake manifold need to be modified for FI>?
thanks
Old Dec 16, 2004 | 05:30 AM
Stephen Max's Avatar
thanks
I haven't heard of too many head gasket problems. Actually I can't remember of any at all, but most of us aren't running boost that high.
You don't need to modify the IM at all when you install a TC or SC kit, but having a MEVI definitely helps, and by this weekend I'll know if the 00VI is an improvement. The larger diameter Pathfinder throttle body also probably helps, but there's been no conclusive before and after dynos to prove it.
Old Dec 16, 2004 | 07:10 AM
subs1000w's Avatar
there are only 2 things that can cause a blown head gasket
severe detonation
extreme block flex from high HP levels
so just make sure you have a good tune and you should never have to worry about it
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
dshinn
Sep 26, 2015 08:07 PM
