intercooler kit??
intercooler kit??
i've looked around, asked people and still cant find an intercooler kit for my 98 maxima!! i need sum info on if they even make 1 for my 98 gle and if not could i just get a universal intercooler and sum how make the piping and make everything fit on it rite. thks for reading.
You not gonna fit a "kit". You can find an intercooler that will fit under your bumper support then have the piping made. I just bought a 26x6x3.5 intercooler off ebay for $280 shipped
Originally Posted by slimer
how many more parts mike?
Still need alot. BOV, wastegate, fuel pump, boost gauge, fuel pressure gauge, and clutch. Will be getting one of them from my brother for christmas, but don't know which one so I am not buying anything else till after the holidays.
i found some really nice bov's on ebay for like $60 that usually retail for like $250, like the txs rfl.
My piping is flanged for an HKS SSQV so that is what I am going to get
Originally Posted by meccanoble
wow, that intercooler is going to fit without any cutting? wont u automatically lose your fog lights due to the piping?
I did alot of measuring and a little mock up before I bought it. The intercooler will fit without having to cut or remove the bumper support. Now the piping is a different story. I may have to modify the piping a bit. On_alert who built the kit could not remember the length intercooler he got so I had to kina judge by some pics and just go with what I thought was best.
I am prepared to loose my fogs. By looking where the piping has to come through I would say they are gonna have to go. I don't really care though.
yea, but would have done much better for a stealth look
If I do lose the fogs I am going to try and see if I can figure out how to keep the lens in place. Just remove the housing and wiring. That way it will look stock but the fogs just won't work
I can build piping for 3gens... Got a extra car here to mock up all the peices.. That's using my way to do the turbo mounting,routeing ect. I can remove and replace just about anything in my engine bay faster and easier than factory. Down pipe comes off in 3-5min. Collector/s to up-pipe feeding turbo about another 10 min. Turbo stays in place from another support bracket. Intercooler comes off with 2 bolts (along with rebar) Piping is very easy. I lost my fog lights but I have not finished my bumper yet. I'd like to help anyone if they need it. All tools and parts hoist ect easy to use at my building..
Ask anytime.. Love this stuff...
Scott~
Scott~
Scott~
Scott~
mike, where are you going to get your piping from, exhuast shop? How are you going to do your turbo piping, reverse y-pipe? I need some help finding someone to do mine but since I'm in ut there isn't much shops that would know what they're doing.
If you can't weld or don't have friends that weld then I would suggest buying the PFI set up. I would not trust some random shop to make my piping
I buy all mandrel bends and streight pipe. Cut and weld. I use 1/4 plate steel for connections to make things easy to take apart that won't leak. You need support brackets holding it all together so they won't fracture with the movement of the engine!!!! The most frustrating thing is having exhaust break every few months because it's not supported correctly. I have not done anything newer than my car (89) but I'd be glad to do a newer one and make all the Jigs so I can make a "kit" for other people. It won't be 3000.00 or more like normal kits.. what a rip!
Thanks! Scott
Thanks! Scott
Awsome.. Sound like fun! I can get the bends or post a list. I'll need to know what parts you already have! It's a prity basic list some of the other stuff I'll have there at the shop. If you want pic's of how mine's setup I'll send them when I return from St. Louis.
I'm kinda at a stand still with my car.. just bumper and tuneing left to do. Starting all over again sounds like a fun challange!
~Scott
~Scott
Anyone's welcome any time. The more Bernard teaches me the better
I got the 3gens down. You guys with the 4th gens.. Send me a pic of your engine bay! I almost bet you'll need to re-locate your battery to the trunk like I did. Yea.. it takes some weight off the front end but it also makes it 10000 times easier for installing the turbo setup! For you guys with 3d gens(with same engine as me) VG
I can make pipe from stock manifolds to turbo... turbo downpipe.. going to be 3" DP to a small section of flex that go's right above the stock sway bar. You'll have to run 3" or 2.5" from there to the back of the car. I'll mock it all up on my car to make sure it's right. Now that I've got one perfected you guy's stuff will be a breeze!
~Scott
. I got the 3gens down. You guys with the 4th gens.. Send me a pic of your engine bay! I almost bet you'll need to re-locate your battery to the trunk like I did. Yea.. it takes some weight off the front end but it also makes it 10000 times easier for installing the turbo setup! For you guys with 3d gens(with same engine as me) VG
~Scott
~Scott
~Scott
How much you think you'd charge me to mock up a exuastkit with a turbo flange that will fit a GARRETT T3/60-1 W/ .63 A/R TURBINE ? I'm looking to run relativey serious serious power and need a good reliable setup,only thing is I don't know how to go aboout getting my own custom exuast done. Since you seem to have the ability well underwraps,I'd love to work with you in getting one made up and shipped to me.
I am first going to try an use the intercooler piping that I already have regardless if I lose my fogs. I just want to get it up and running then I can change things from there.
Dam*t I wish I live on the east coast or I'll be visiting too. I'm need to move back to civilization... let me know how the deal goes. Also, I found a guy locally selling his SC kit for $1700. Think I should bite or hold off for a turbo?
Definatly hold out for the Turbo! It's worth it! Bob.. I PM'd you.. anyone else that's interested in help or making pipeing ect.. UR50SLO@aol.com
This isn't some "buisness" to make money off you guys this is me helping you out and getting you boosted. Pay for my parts and some of my time and I'm happy. I just enjoy doing this kind of work.. It's very fun for me.
~SCott
~SCott
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
You know you should heat wrap that **** too
