Underdrive pulleys with supercharger?
Old Jan 5, 2005 | 06:29 PM
dadiesel's Avatar
Is it ok to use underdrive pulleys with a supercharger, because I was told otherwise. If so, have any of you w/ SC's noticed any difference with them?
Old Jan 5, 2005 | 06:50 PM
vortechpower's Avatar
I have been told or I have heard that the underdrive pulley is not good with the sc ...
Old Jan 5, 2005 | 07:21 PM
chris'smax's Avatar
Underdrive pulley+SC=no good, you want to go with a lighter drive pulley made by Unorthodox Racing(i believe that is who makes it)
Old Jan 5, 2005 | 07:34 PM
SPiG's Avatar
SomePsychoGuy
You would get less boost unless you got a smaller pulley for the SC. If you get both then you would have very less belt connected to the two most important pulleys. That would probably be a bad idea and would increase the chance of slipping. The lightened (but not underdrive) one from UR is probably your best bet.
It would probably make more of a difference since you have more power than an NA max. However there are more important mods to get when going SC. A good fuel system and some other mods are just more important.
Old Jan 5, 2005 | 07:46 PM
chris'smax's Avatar
or you can just do them all
Old Jan 5, 2005 | 08:07 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
right, you can do them all.
i had planned on getting one of the lightened crank pulleys with my xmas $, but i bent a rim and got volks instead.
ferhan, the guy who had the kit before me, had a 2" pulley paired with a UDP.
he pushed maybe 9psi, but people say that there should be major belt slip due to the smaller contact surfaces.
Old Jan 5, 2005 | 08:45 PM
Broaner's Avatar
2060lbs and falling...
2" and 9PSI? That is all I need to hear. I guess I'll need to add that to the buy list next winter. How much are the lightened ones? I don't have power steering so I'm interested in having UR make a lightened pulley that doesn't have the power steering groves and therefore would be even lighter.
Old Jan 6, 2005 | 01:41 PM
Cutler's Avatar
No UR pulley use is recommended....
Old Jan 30, 2005 | 01:49 PM
HTPerformance's Avatar
When you use the Vortech kit does it come with a 6-rib crank pulley? or is the 4th and 5th gen have a 6rib crank pulley already??? I bought a 4-rib pulley to replace the 6-rib on the SC, cuz the 3rd gen only has 3 - 4rib pulley slots on the crank pulley.
Brian
Old Jan 30, 2005 | 06:48 PM
Broaner's Avatar
All VQ's have a six rib crank pulley.
Old Jan 30, 2005 | 07:00 PM
all 3 belts are 6rib? or just the outer one? what acessories does it normally drive?
Old Jan 30, 2005 | 08:19 PM
slimer's Avatar
the outer one, the other part drives the power steering and thats a 4 rib
Old Jan 31, 2005 | 09:53 AM
Broaner's Avatar
VQ has only two belts(Mine has only one). Outer is six rib and in OEM config drives the A/C and Alt. Inner is four rib and in OEM config. drives the power steering. All other accessories are chain driven.
Old Feb 2, 2005 | 04:28 AM
dadiesel's Avatar
So a lightened drive pulley is ok w/ a SC?
Old Feb 2, 2005 | 06:16 AM
Stephen Max's Avatar
Shouldn't be a problem.
Old Feb 2, 2005 | 09:21 AM
Broaner's Avatar
I've always wondered how much lightened pulleys would do on a SC'ed car. Isn't most of the drag loss due to air resistance the impeller blade encounters? If anyone cares, I plan on having ASP make me a OEM diameter crank pulley except without the Power Steering ribs to further reduce weight.
Old Feb 2, 2005 | 10:20 AM
At high rpm yes. You can estimate the hp loss from the blower by multiplying CFM x boost pressure x .0044
where CFM is the flowrate through the blower in cubic feet per minute and boost pressure is in psi.
So, if you are pushing 500 CFM at 10 psi, the blower is using about 22 hp. On top of that there is hysteretic loss through the drive belt, but that is probably pretty low. There is also frictional loss from the SC gearing and bearings.
Old Feb 2, 2005 | 10:39 AM
Broaner's Avatar
Cool. Thanks for that formula. Is the flow of the blower linear? Or is that what those eliptical graphs are for? The frictional losses you speak of are what I want to reduce by doing away with the secondary idler pulley.
Old Feb 2, 2005 | 10:43 AM
Air flow through a centrifugal supercharger is exponential with impeller speed.
Old Feb 2, 2005 | 11:16 PM
dadiesel's Avatar
So last question...is it going to be worth the money?
Old Feb 2, 2005 | 11:22 PM
dadiesel's Avatar
also, is called an Unorthodox Racing Ultra S Standard Belt Crank Underdrive Pulley? Just want to make sure that is the one before I buy it.
Old Feb 3, 2005 | 04:40 AM
slimer's Avatar
thats the one.
no one has tried it yet. i was going to get one for with my xmas bonus, but then it had to go to new wheels instead.
if you do get it, do before and after dynos!
Old Feb 3, 2005 | 07:26 AM
LatinMax's Avatar
Originally Posted by slimer
thats the one.
Correction...I have tried it and notice a huge difference. But never got to dyno the difference. (just by dyno) Big difference is that I het the rev limiter much quicker.
Yes that is the one I got. I git it thru Courtsey Parts. I can't remember the price, but it was around $200 bucks.
IMO a worth while mod.
Old Feb 3, 2005 | 08:17 AM
slimer's Avatar
cool, i didnt know that you had tried it!
Old Feb 4, 2005 | 08:45 AM
chris'smax's Avatar
Just bought one
Old Feb 4, 2005 | 06:15 PM
dadiesel's Avatar
Chris, let me know how much of a diff it makes with you being SC'd too.
Old Feb 6, 2005 | 06:49 AM
dadiesel's Avatar
Latin Max--What kind of SC setup are you running w/ your crank pulley.
Old Feb 6, 2005 | 07:06 AM
Requin6's Avatar
got an exact part #? all the descriptions are very similar and courtesy appears to not stock them anymore.
Old Feb 6, 2005 | 10:55 AM
LatinMax's Avatar
I have the V2, 2.87" pulley, FMIC with 2.75" piping, CAI, Dual stage water/alcohol injection, eManage, J&S, PFI 510 injectors, and a auto custom tranny.
Today 08:49 AM
Make sure call and talk to Brian. I will call also and get the part number from him.
Old Feb 6, 2005 | 06:09 PM
dadiesel's Avatar
LatinMax- What are FMIC, J&S, and CAI? Also, where did you get your water/alcohol injection system?
Old Feb 6, 2005 | 06:58 PM
Broaner's Avatar
FMIC = Front Mount Inter Cooler
J&S = A device which monitors and warns of detonation. Basically a really good knock sensor.
CAI = Cold Air Intake.
Old Feb 6, 2005 | 08:11 PM
LatinMax's Avatar
The water/alcohol injection system, is made by Cool Mist and eveything that was said above by Broaner.
Old Feb 7, 2005 | 10:30 AM
dadiesel's Avatar
Thank you both
Old Feb 11, 2005 | 11:41 PM
ptatohed's Avatar
Licensed to Spell
:o)
If you look on Unorthodox's site, they want $230!!! And that's before shipping. Ouch.
Ultra Sc 12-Volt Charger Series Crank Pulley 121001012
http://www.unorthodoxracing.com/nissan_maxima.html
http://unorthodoxracing.com/cgi-bin/...Code=121001012
However, I requested a group buy and this is the price/response I got from Import Car Parts:
http://forums.maxima.org/showpost.ph...&postcount=144
$184 shipped. Not bad. And I don't beleive it needs to be a group buy either. I think I might just go for it.
Old Feb 12, 2005 | 04:30 PM
dadiesel's Avatar
Whats the difference between the Street Crank Pulley and the 12Volt Charger Series Crank Pulley?
Old Feb 12, 2005 | 11:47 PM
Broaner's Avatar
The Street Crank is an underdriving pulley. The Charger Series is OEM diameter.
Old Feb 13, 2005 | 12:31 AM
LatinMax's Avatar
The Charger Series us what you need on a SC car. That's what I have
Old Feb 14, 2005 | 07:52 PM
dadiesel's Avatar
How long of an install would it be at a shop?
Old Feb 14, 2005 | 07:55 PM
Broaner's Avatar
I assume your talking about the pulley. I'd guess about an hour.
Old Feb 16, 2005 | 01:37 PM
dadiesel's Avatar
thanks for the info .
