Rebuilding my turbo feed pipe.. need opinions..
Here is what I am looking at doing.. I am going to make the front and rear banks join better. I am trying to figure out which collector to use. I know basicly they are the same, but does one flow better than the other?
And I am tossing up either 2 inch or 2 1/4 inch ( inner diameter ) into the collector (from the front/rear banks) and then 2 1/2 inch (ID) out of the collector (to the turbo).
Thoughts? Opinions?
Thoughts? Opinions?
Originally Posted by spanishrice
is the turbo a 4 bolt standard flange? Those are 2.5 inches across right?
It's almost 2.5 inches wide.. Inner Diameter. I think it's 3 inches wide from the outside
Bags, you should PM Redmax...if I can remember, his new piping setup uses #2, he should have some insight. when it was up on the lift a few months ago you could see the drastic reduction in the amount of piping used as well as the total length compared to the old setup, it was an amazing change
Originally Posted by Jeff92se
Bags. I'd use the one that's more durable. I don't think the flow differences will be that much.
ok, thanks.
FWIW.. I can get #1 made 10 inches in length 2 1/4 in and 2 1/2 out for $15 from the place I buy my scrap pipes
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
